Previously TUNGA
Hope some one can give me a bit of help . For some reason my passenger external door handle has become lose. it wobbles about one millimeter,how do i go about tightening it up . any advice would be great as its a bit annoying.
AU2 XR8 Pursuit Ute Liquid Silver |
Previously TUNGA
sorry put it in the wrong place
meh.
![]() Join Date: Jul 2010
thats fine mate. Dauphin will see it and move it anyway
![]() What you do to do up the bolts, is remove the door trim. what you need: 10mm socket, PH2 Phillips head screw driver, Flathead screwdriver 3x screws along the bottom under the black/grey caps (dependant on series) 2x screws along the side of the door trim (looking at the side of it with the door open) 1x screw under the power window switches 2x 10mm bolts under the two grey/black caps that are just on the front of the door trim then when you pull away, just make sure you are careful with the clips holding it in.. It will be a little hard to pull off, but just be careful with it if it doesn't come off in a certain place, check around it for bolts/screws.. im quite sure thats all the screws/bolts, but its been close on 1year since i've removed an AU door trim. then just look at the handle, and using the 10mm socket with extension bar, just tighten the two bolts holding the handle in. Let us know how you go ![]() Tony
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear |
