19-12-2010, 07:10 PM | #1 | ||
Former BTIKD
It seems that our power Ariel is now a manual one. I'm assuming this only a cable problem as it went up and down a little before dying, so how much drama can I look forward to in replacing it ?
19-12-2010, 07:22 PM | #2 | ||
Flairs - Truckers Delight
Yeah they're not particularly fun. I remember changing one about 7 years ago, it's under the wheel arch cowling. You need 3 very small hands and a large amount of patience.
19-12-2010, 07:46 PM | #3 | ||
Former BTIKD
Bugger...But we'll be up your way in Jan/Feb and seeing as your experienced I might just bring it to your place
19-12-2010, 07:49 PM | #4 | ||
Next upgraded Mk1 Leopard
I did my sons and its a pain. Be prepared for some 4 letter words (you know wood, some, duck, %$@k etc)
UK
19-12-2010, 08:16 PM | #5 | ||
"quiet kids, gaso's coming!"
19-12-2010, 08:34 PM | #6 | ||
Mine wasnt hard, just a couple of 10mm bolts. Think I already had the 1/4 panel off though.
19-12-2010, 09:58 PM | #7 | |||
UK
19-12-2010, 10:21 PM | #8 | ||
meh.
pity that GasOLane's antenna is in the rear quarter (fairlanes have them in the passengers rear quarter next to the boot lid for anyone who didn't know)
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear |
20-12-2010, 12:57 AM | #9 | ||
When in doubt, GAS IT!!
Changing the Fairlane aerial is easy enough, just a locking ring on the outside of the panel and a nut down by the motor. You should be able to swap one out in less than 20 minutes. If you can still hear the motor working when you turn on the radio then you should only have to swap out the mast. If you are just going to change the mast I'd have someone there to help cos once you have freed it from the sleeve you need to drive the aerial up and out which is easy enough as it'll drive itself out once you get it moving but putting it back in is a bit tricky as you need to feed the toothed spline back into the body till it finds the sprocket at the bottom of the shaft and then it'll just wind itself back in. You can't be feeding the spline into the sleeve and turning one the radio at the same time. Be sure you get a Fairlane aerial not a falcon one as the 'lane one is thicker and slightly shorter and the falcon one won't fit into the fairlane aerial housing properly, too long and too thin. Also be sure you salvage the brass collar from the base of the mast cos that's what keeps it in once the collar goes back on.
If I were you I'd be looking for a good second hand unit you can pinch the mast from cos new ,the mast is 4x the cost of a falcon one. Bushbasher
20-12-2010, 10:25 AM | #10 | ||
Dont for get to buy an LPG aerial mast
UK
20-12-2010, 10:36 AM | #11 | |||
Former BTIKD
20-12-2010, 10:42 AM | #12 | ||
Hi. The fairlane antenna is unique to the fairlane(/ltd?) and not serviced by the aftermarket industry. putting in a non genuine antenna throws out the timing and the antenna doesn't go all the way down and get worse every time it goes up and down. The good news is that if your motor still runs you can replace the mast and cord fairly easily, first remove antenna and open the case to remove any of the nylon cord then refit to car and before fitting the top nut turn on the radio to make the motor run in the up direction and then poke the new cord down the hole and turn off the radio which will draw the cord into the antenna, push the mast in to place and refit the nut. 1/2 hour job tops including beer time. Cheers MD.
20-12-2010, 11:16 AM | #13 | |||||
Former BTIKD
20-12-2010, 11:33 AM | #14 | ||
Hi yes wasted a day on a customers car then fixed it in 20 mins with genuine mast from ford. Cheers MD
20-12-2010, 03:56 PM | #15 | |||
Bushbasher
