T3 TE50 Blueprint
Has anybody replaced the BEM on their AU? Do I have to got through Ford or is aftermarket ok? Anyone know what they are worth?
Thanks -Craig |
Just head to the wreckers, and get one,
Welder/Fabricator at Beaudesert Exhuast Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors |
Although I think that you will need to go to ford to get it programed for your car? Or is it different to the ba's
Now Ford-less ![]() But good things are coming in 6 months
#4 | |||
You can't stop the signal
You can pick on up second hand, but you will need to go to ford to have it reprogrammed to suit (they are coded to the ecu).
It doesn't cost much to have it done, but the only point is the car won't start till it is done. Cheers
meh.
![]() Join Date: Jul 2010
if you dont want to tow your AU3 XR8 to the local ford dealer after installing the new BEM/BCM, drive to your closest ford dealer first, park where they can get to it, then remove the old BCM, put the new one in (there is a screw at the bottom of the dash where it's held in), then get them to program it.... to replace it, i can do it in an EL and AU in 4 mins max... its too easy..
yep - that's the way to do it.
Aftermarket BEM????? Heheheh, good luck with that! New from Ford ... or take you chance with one from the wreckers. |
T3 TE50 Blueprint
Thanks everyone for their advice, I will take it all onboard. I'm only about 1km from my local Ford dealership, so at least they are handy.
-Craig |
not here much anymore
I believe you can actually get an aftermarket one - but it is actually a refurbished factory one. I have tracked down one for a VR Senator through work.
RAM 1500
That's interesting that the Ford BEM will suit a Senator??????
Heheheheheheh |
#10 | |||
RAM 1500
There is a place on Moss st at Slacks Creek that rebuild them. Cant remember the name but i know where they are. They quoted me about $240 to fix mine but i haven't got around to doing it.
AU XLS. |
I am pretty sure that you will find that injektonics do refurbished ones.
AU III Forte wagon - V8, 5spd man, lowered, 18" Honeycombs, Stock diff rebuilt with TruTrac LSD, Leather Ghia interior/dash, custom twin 2.5" into single 3" exhaust. Wagon Build AU I Forte Sedan - No longer
Toy Car Build |
