09-10-2010, 10:38 PM | #1 | ||
not here much anymore
Could someone please point me in the direction of some notes on how to remove the entire interior from an AU (ute specifically but sedan notes will do).
Just want to have some reference points handy before I attempt it. Thanks
2024 F150 XLT
09-10-2010, 10:40 PM | #2 | ||
Hey aust, just have a looksee at the workshop manuals on the site, everything there
09-10-2010, 11:23 PM | #3 | |||
AU DIE HARD
Shoot Ben (Super roo) a pm he had his all out and put a Fairmont dash and trim into his he will be able to give you some clues or see his build thread .about page 5 or 6
http://www.fordforums.com.au/showthr...3&page=1&pp=30
10-10-2010, 12:40 AM | #4 | ||
Probably should clarify that its only really the seats I am wondering about - the rest I know how to do. Just worried about unplugging the wiring etc.
2024 F150 XLT
10-10-2010, 11:54 AM | #5 | ||
Disconnect battery, remove mounting bolts, lie seat back to access pretensioner wiring plug (under seat), unplug connector and remove seat. Did mine yesterday so I can finally put all my sound gear in
Hope this helps Wes
White MY04 Subaru Impreza WRX Hatch - Stock, airbox resonator mod, lowered on king springs Marine Blue EBII XR8 - GT40p's, Paceys, 3in mandrel bent exhaust, Explorer Manifold, YT 1.72 RR's, 65mm TB, 75mm MAF, Thermo's...now manual 1967 Ford Futura coupe 289 C4 stock cruiser
10-10-2010, 03:30 PM | #6 | |||
I also have to remove the rails too - installing new carpet so everything has to come out but Im sure Ill be able to manage them.
2024 F150 XLT
10-10-2010, 05:01 PM | #7 | ||
The seats come out complete on the rails.
I dunno why you're stressing ... honestly, removing the seats is one of the easiest jobs. No tricks involved except for the socket head retainers for the rails/floor. |
10-10-2010, 07:46 PM | #8 | |||
Wes
10-10-2010, 11:57 PM | #9 | |||
2024 F150 XLT
11-10-2010, 12:41 AM | #10 | ||
dont worry about the wireing unplug and away u go.. worry bout the probems later.. youll need a torx screw thing if its the same as the ea-ef/el fords ..
fordforums.com.au/showthread.php?t=11329125 The XR Build That I Shouldn't Of Sold DAMN! Current Daily: 2019 Ford Ranger Raptor weekeder: 91 soarer project: 2005 Bmw e46 coupe 1jz bf mk2 xr6 ute magnet |
11-10-2010, 12:58 AM | #11 | ||
Regulator
Just be careful not to scratch the paint on the sill area or plastics as you take the front seats out.
Regards Bobby Current Cars: 2000 AU2 Fairmont (2019-current) 2003 BA1 Falcon Divvy Van (2017-current) 2009 VW Mk6 Golf 118TSi (2020-current) Previous Cars: 2003 MCX10R Avalon VXi (2017-2020) 1995 EF1 Falcon GLi (2016-2019) 1997 XH2 Falcon Van OPT20 (2016-2019) 2006 BF Fairlane Ghia (2013-2018) 2001 AU3 Futura (2010-2013) 1996 EL Fairmont (2008-2010) 2004 BA XR6 (2005-2008) 2001 AU2 Forte (2005-2006) 1988 EA Fairmont Ghia (2003-2005) 1984 AR Telstar TX5 Ghia (2001-2005) |
11-10-2010, 03:34 AM | #12 | |||
Pro Street Au Ute
11-10-2010, 02:13 PM | #13 | |||
Former BTIKD
(When's the next one Aust ?)
11-10-2010, 02:30 PM | #14 | |||
11-10-2010, 02:38 PM | #15 | |||
All good T3man.
2024 F150 XLT
12-10-2010, 02:42 PM | #16 | |||
You can't stop the signal
If you’re doing the carpet Austin, the list of things that have to come out are:
Seats Center consol Scuff plates Bottom b pillar trim (which requires top B pillar trim and rear side window trims off) On top of this you will need to undo the bottom dash mounts on the front of the trans tunnel. To get the carpet out around these is a fun job. You actually need to bend these tubes out slightly and then slowly wiggle the carpet out. Also, to get the vinyl floor out from around the shifter (that large plastic support) I had to slit it from there to the airbag module. I can't remember doing this to the carpet though, but you may have to. It doesn't matter though as it is hidden by the center consol. Good luck with it all. At least it's not a dash change Cheers
