Old 30-08-2010, 12:37 PM   #1
ebokazion
Default fire sequence for 2lt escort
hi,
i was hoping someone would be able to help me witht the fire sequence for my 2lt ford escort.
ebokazion is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2010, 02:08 PM   #2
Pazuzu
Pazuzu is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2010, 02:10 PM   #3
Puzzlescort
Rally Nut
Puzzlescort's Avatar
too slow at typing - lol
heres a good pic to help out
Pinched (borrowed) from RS Motorsport
Puzzlescort is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2010, 12:37 PM   #4
ebokazion
Default please help me get it started
thanks to both of you.
however i still have a problem, it wont start!
i have plenty of spark, plenty of fuel going in, will the gap in the points make a BIG difference? i did the gap by sight as i dont have a feeler gauge.
it turns over very easy, just doesnt kick into life....
any suggestions
Old 31-08-2010, 03:27 PM   #5
Pazuzu
Points gap will make a difference if it's way out. Best bet is to just nip into Stupa Sheep or Repco & buy a feeler gauge, they're probably only about $10- $15 for a cheap one that will do the job well enough.
If it's not starting, double check your connections from Dizzy-to-Coil, Dizzy-to-plugs. Besides that, it could be a lot of things.
Old 31-08-2010, 04:21 PM   #6
ebokazion
thanks heaps, will give it a go tonight....
Old 04-09-2010, 09:31 AM   #7
JG65TE
JG65TE's Avatar
petrol............... match..............run...........call insurance
JG65TE is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2010, 02:41 PM   #8
dennis
timeing could be out 180 deg.remove disy turn engine over to tdc replace disy. dennis
dennis is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2010, 03:47 PM   #9
ebokazion
thanks mate, ill try it and let you know how i go over the weekend.
Old 11-09-2010, 11:22 PM   #10
JG65TE
JG65TE's Avatar
easy way to find tdc compression stroke. Pull no 1 plug, jam dunny paper in and bump the engine on the starter til the paper pops out, U now have tdc comp stroke. Toss the dissy back in and align the next firing plug lead according to the cap onto no 1. The fact that u have spark means ur points gap is close at least, and I dont really see u being 180 out if the engine turns freely, but ya never know i guess. Apologies for the fuel , match run joke...... thought u had it sorted out.
Doc
