Old 18-08-2010, 11:11 PM   #1
Andrew92
Default ef falcon
do u guys know what size the front speakers are in a ef falcon? will 5.25inc speakers fit in the front? also what size are the speakers in a fg? will 5.25inc speakers fit in that?
Andrew92 is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2010, 08:47 AM   #2
FADI75
Sponsor
hi
not too sure, your best is to see a website sponsor and ask them the question FTG autosalvage
cheers
ASL
AUTHORISED FORD REPAIR CENTRE
email: info@aslautomedia.com
Old 19-08-2010, 10:24 AM   #3
MAD
Petro-sexual
MAD's Avatar
5.25" is just about a perfect fit in the EF. Depending on how the speaker manufacturer measures their speaker, you can fit up to a 6.5".
Here is something I found a while ago when searching for similar answers.
Originally Posted by Pyroay
EF/EL Door Measurements
Hole size: 126mm
Width around hole: 160mm ( recessed section around hole)
Allowing 2-3mm gap to clear the window the following is a guide to the max mounting depth allowable
Depth @ top of hole 60mm
Depth @ centre of hole 70mm
Depth @ bottom of hole 72mm
If you use a 12mm MDF spacer ring then the maximum depth in hole centre is 92mm. Below is a 4" midrange mounted on a 6mm MDF spacer with rubber under one side to give it an angle
Max depth speaker you could fit into the door and still have the window wind up and the door skin fit on would be 92mm deep in the middle.
An additional spacer ring can be made up to 12mm thick and this gives an additional 12mm mounting depth without fouling on the standard door skin and allow the mounting of 6.5” speakers. Alternatively you can use 9mm MDF and use some rubber under the front edge to give it some backwards angle (which is desirable) Even a few degrees can make a big difference.
EL Fairmont Ghia - Manual - Supercharged
- The Story
MAD is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2010, 07:08 PM   #4
Andrew92
thanks guys.
