Old 05-09-2009, 12:43 PM   #1
rosco426
Charger Lovin'
Default AU Series 1 Question
I was wondering if anyone can answer me this (which I'm sure someone can).
Series 1 cars had different front end components which don't allow Series 2/3 brakes to simply bolt up (and don't I hate that). My question is how did certain cars get optioned up with Tickford brakes from the factory and bolt up? Did they use a different bracket or simply using all the left over stock from the E Series cars.
I ask because i want to my single pot brakes off my Series 1 and came across that thought.
Cheers,
Rosco
rosco426 is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2009, 12:46 PM   #2
mattp
mattp's Avatar
The series 1 AUs that came with the Tickford premium brake set-up had a different stub axle (upright) to which the caliper mounted. The rest of the front end was the same as other series 1's (sway bar, control arms, etc)
I did this conversion on my old AU, but the stub axles are hard to come by, you really need to buy the whole set-up from someone like FTG, which is what I did.
mattp is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2009, 12:57 PM   #3
rosco426
Charger Lovin'
Okay, so they were a different stub axle, that makes sense. So effectively with that stub axle any later model calipers would bolt up.
I like the thought of getting a complete front end but I don't think my brother will want to fit it and would rather spend time on my other car.
Would Ford still sell these stub axles new by any chance?
Old 05-09-2009, 01:33 PM   #4
UU TS50
T3 TS50 075
UU TS50's Avatar
lots of useful info here
http://www.fordforums.com.au/showthr...69#post2720169
Cheers John
My car T3 TS50 #75 Blueprint manual 1/4 mile 13.38 @ 102.97 mph TS 50 = 237.1 rwkw
UU TS50 is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2009, 02:23 PM   #5
rosco426
Charger Lovin'
Yeah I've looked at that thread heaps but wasn't what I was after.
Old 06-09-2009, 12:03 AM   #6
mattp
mattp's Avatar
I don't think they do still sell them new unfortunately, I seem to recall someone on here looking at a used TE50 that had been in an accident and had a cracked upright amongst the damage, and it was the only part that was no longer available from Ford.
Old 07-09-2009, 03:06 PM   #7
rosco426
Charger Lovin'
Hmmm, that doesnt sound like the best idea then. I'll keep an eye out for some on a wreck early T car or spec'ed up XR6/8 that has decent ones. Otherwise complete front end swap here we come. Cheers for the advice Matt.
Old 08-09-2009, 09:05 AM   #8
Papa Smurf
Papa Smurf's Avatar
You can still buy the R/H one from Ford but rather expensive, like $2100.00.
You would actually need to change the lower arm as well as the series 1 sway bar mount would be in the way of the caliper. I believe that most wreckers can do a good deal on control arms and stub axles or, you could buy a written off AUII, III, BA that had a big rear ender?
Papa Smurf is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2009, 11:52 AM   #9
rosco426
Charger Lovin'
Yep, it seems as it is the only option. I'll probably hold out then till I have space at home to do it. Thanks for the response guys.
