G'day all, i am currently doing a convertion on my sons mrk2 cortina we have put a 2lt pinto motor in it and was wondering if anyone here knows were i should start with getting some headers for it. I am not sure what model car the motor came out of so the local exhust bloke doesn't know were to start.it has a shitty old pair of extractors on it now and they are a really bad fit as they are hitting the steering box and gearbox mount so they wouldn't be the best thing too model a new set off. Any ideas would be most welcome thanks ...Craig
u culdnt possibly tell me the part numbers and stuff that are on the alternator could you?
and my esky has the same issue, so im gonna see if they can be heated and bent, or just rewelded differently. |
Rally Nut
there is a difference between escort & cortina extractors
- grwwalker, if your extractors are hitting the alternator my first thought would be to look at what brackets are being used.... every pair of extractors I have seen are fairly constant in the alt area... but if they are hitting the steering as well - you guys might need to do a swap lol |
try custom made. not hard for any decent exaust shop
HOMER: You can do things theright way the wrong way or the max power way! LISA: Isnt that the wrong way? HOMER: Yes but faster! |
Mk2 Racer
Either Pacemaker or Genie make extractors for the Pinto but your exhaust bloke should be able to source then easy enough
about $390-00 Les |
