Old 26-08-2009, 01:27 AM   #1
agird
Default 1988 Laser fuel leak
Hi Ford-Folks,
My son inherited his nanna's 1988 Laser Ghia 1.6. When it starts there is often a smell of raw fuel, I've had several looks around the engine once its warm but can't see any leaks.
Today I found the leak and it is coming from this cylindrical metal thing that looks like a fuel filter (but isn't) which sits under the passenger side of the air cleaner. The fuel line goes to it and there seem to be a couple of breather pipes or something. It leaked pretty bad but only for a minute or so after starting.
Got any ideas?
agird is offline   Reply With Quote Multi-Quote with this Post
Old 26-08-2009, 09:37 AM   #2
Peter B - CV8
Pressure regulator ?????? Should be a pretty easy & cheap fix.
Peter B - CV8 is offline   Reply With Quote Multi-Quote with this Post
Old 26-08-2009, 08:47 PM   #3
agird
Der.. ok I could see in the light that its a mechanical fuel pump. Strange thing is that is doesn't leak at all when the engine is warm. I wonder if, when its cold, the bypass leaks as it tries to send excess fuel back to the tank.
Old 26-08-2009, 08:58 PM   #4
Fled74
The Thread Killa
Fled74's Avatar
It could be that the rubber diaphragm inside the pump doesn't flex well when cold, thus letting fuel out one of the breather pipes, but then becomes more pliable when it warms up.
I had a very similar problem with a Daihatsu I used to drive.
"It is the mark of an educated mind to be able to entertain a thought without accepting it." - Aristotle
Fled74 is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2009, 12:31 AM   #5
agird
Interesting, I've never heard of that but it fits the symptom. Thanks for that.
