Old 05-06-2009, 06:44 PM   #1
cram72
Default The Dreaded Red Light!
I was always educated as a young man that red lights were good things and if in premises of questionable character they were even better!
My 79 RS2000 however is displaying the dreaded alternator light and thus is bringing me only pain, all connections electrical have been cleaned and redone however this little red demon still displays. Checks conducted state that the alternator is chucking out charge and the battery is good, no dimming head lights or problems, I;ve checked it all. But it won't go out, I just want to remove the bulb from the dash but this problem is bugging me some wont give up just yet.
Any ideas?
cram72 is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2009, 06:53 PM   #2
Les
Mk2 Racer
Les's Avatar
I'd suggest checking your alternator as the light wire generally shorts to earth until the alternator kicks in, the diodes then open the circuit allowing the light to go out. If every thing else stacks up OK this is probably the culprit,
Cheers, hope this is of some use.
Les is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2009, 07:37 PM   #3
Engine Guy
Ford alternators are known for developing faults...
1st check would be the Carbon alternator brushes
2nd would be the Diode pack - there are 9 diodes all together..check them all
3rd a voltage regulator fault (not a common fault)
4th most unlikely would be the stator & field windings
Fixed heaps of these...
Engine Guy
Engine Guy is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2009, 08:38 PM   #4
philfree
hi
You said it's charging fine even when the lights on means 2 things. 1Ttheirs a short to ground some where between the alternator and the light as already said. or 2 The regulator on the alternator could be faulty but i highly doubt that.
Thanks
philfree is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2009, 01:27 PM   #5
cram72
Thanks for the advice philfree, I removed the dash to check the rear wiring and discovered that a quite intricate set of new wires had been soldered to the wiring card inclusive of a regulator, I noted one connection had snapped to the alternator light. Once placed on the bench all wires promptly fell away from the wiring card and thus I now have no fuel guage or templ guage. It looked like a very dodgy earthing set up! Question, can you get repro cards or should I take it to a auto electrician to sort and rewire? Or say bugger it and just fit after market fuel and temp guage however alternatior light would still be on.Ahhhhhhhhhhhhhhhhhhhhh. Any advice appreciated.
Old 17-06-2009, 01:46 PM   #6
bloggs24
Just save yourself the trouble and take it to an auto electrician to sort out.
bloggs24 is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2009, 05:22 PM   #7
feral
Otherwise keep an eye out for a dash on ebay.
ZJ Fairlane 351C
SY Territory
Skicraft Excel 350 Mercruiser
feral is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2009, 07:15 AM   #8
Puzzlescort
Rally Nut
Puzzlescort's Avatar
Cram
I am pretty sure I have a few tacho dashes at home, one of them is an RS dash which was in my car before I put a custom dash in - drop me a message if you get stuck, I am sure we can work something out
Puzzlescort is offline   Reply With Quote Multi-Quote with this Post
