Old 23-12-2008, 07:00 PM   #1
blue_focus
Default Tacho
Hi everyone, I purchased a shift light for my focus the other day and was wondering if anyone out there knows how to wire it up? It says that it has to be connected to the fuse box? Any help will be great. Thanks.
blue_focus is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2008, 08:38 PM   #2
Mullett
Badly Focused
Mullett's Avatar
You could have an interesting time with this, as the focus doesn't use a distributor and coil or high tension leads (which these normally rely on). The power from the fusebox would be accessory power, I'm guessing you'll have 3 wires: acc power, earth and a signal wire. The ACC power you can take from anywhere, pull the fusebox from under the dash on the passenger side, and use a test light to find an ACC wire (I used a fairly heavy yellow wire, so try them first ), and then run the earth wire. As far as signal goes, you *might* be able to use the spark plug wire on #1 cyl, but I'm not sure, as they are only a 12v wire, the coil-on-plug ignition system means that there are no high-voltage wires in the system.
-RM.
07 LT CL, CAI, timing, XR5 springs, LS Zetec wheels
16.045...0.05 of a second! I wanted a 15sec pass!
93 GSR/Evo3...too much to mention, 12.2sec 1/4, FOR SALE!
*Maybe we don't try putting holes in things that sink, yeah?*
Mullett is offline   Reply With Quote Multi-Quote with this Post
Old 24-12-2008, 01:16 PM   #3
Tj-zetec
Knows nothing. Apparently
Tj-zetec's Avatar
pfft, shift lights. Wait for valve bounce.
2008 Electric Orange LV XR5. With dreamscience strategem SCT, K&N 57i Gen2 cold air intake for more fun and demonic vaccum cleaner noise!!
1975 Mitsubishi/Chrysler GC Galant 2-door Hardtop. 4G63 DOHC heart transplant nearly complete!
Check out the build over here
Tj-zetec is offline   Reply With Quote Multi-Quote with this Post
Old 24-12-2008, 03:01 PM   #4
Mullett
Badly Focused
Mullett's Avatar
LS/LT comes with one factory :P ...and if it's valve bouncing...you've got problems. Rev limiter problems :P Talking of which, i heard the other day that the ECU pulls back the timing and richens the mixture for a few seconds if you actually hit the limiter...
-RM.
Old 24-12-2008, 04:30 PM   #5
blue_focus
Yeh but the stock shift light is pretty shitty.. I got a 2 stage Gizmo shift light. Ill give it a try and let you know how it goes. Thanks.
Old 24-12-2008, 08:18 PM   #6
819_FLY
819_FLY's Avatar
-RM.
Care to explain, I don't race my engine so I dont know really
Its not the engine warning light??? hahaha
I drive my American Owned, German Inspired, South African Built, Australian Bought, European Styled, English Powered car. I might have missed something somewhere... 08' LT Ford Focus CL
Check out 819FLY!!
819_FLY is offline   Reply With Quote Multi-Quote with this Post
Old 24-12-2008, 08:28 PM   #7
Mullett
Badly Focused
Mullett's Avatar
Nope, spin it to 6500rpm and a little red arrow lights up
-RM
Old 24-12-2008, 08:49 PM   #8
819_FLY
819_FLY's Avatar
ahh sick
might give it a try next time i go for a drive
Check out 819FLY!!
Old 25-12-2008, 01:34 AM   #9
eXtremist
2007 Ford Focus Zetec
eXtremist's Avatar
-RM.
Where'd you hear this?
eXtremist is offline   Reply With Quote Multi-Quote with this Post
Old 25-12-2008, 07:07 PM   #10
Mullett
Badly Focused
Mullett's Avatar
On these forums :P
-RM.
