ASL automedia Specialising in the upgrade of BA/BF/Territory and FG audio and visual systems. We also repair all Ford (OEM) car stereos and produce OEM quality wiring harnesses. Website Link |
Hi Fadi,
My mate got a cd jammed in my stacker. I took it all apart and got out the 2 jammed cd's in slot 1 and took out the cd in slot 2 as well. Put it all back together and slots 3-6 play no problem. I then ejected the slots and pressed load.... Please wait...then slot 1 sia dload...so I did and the unit won't register there is a cd there. So i press load again and it flashes slot 1...i put in another cd...still not registering. So I now have 2 cd's in slot 1 again. Back to the drawing board.... When I take the unit out again I will release the cd's. Then should all the white slots for the cd's be flat or should slot 1 and 2 be slightly raised?? This was the case the first time I got out the jammed cd's....everything looked fine to the eye...anything I am missing??? Thanks mate, Gilto |
#2 | |||
Sponsor
the best solution is using a new part which's the whole cd mech. there is no easy fix with these things. $450.00 all inc fitted back in your car. or $406.00 supplied only cheers fadi75
FROM FALCON BA THROUGH FGX, TERRITORY SX THROUGH SZ - ICC UPGRADES, REPAIRS & INTEGRATION SPECIALISTS AUTHORISED FORD REPAIR CENTRE website: www.aslautomedia.com.au email: info@aslautomedia.com AUDIO INTERFACES, REVERSE CAMERAS, SATELLITE NAVIGATION & VIDEO INTEGRATION ON FACTORY COLOR SCREEN |
