Old 04-12-2007, 06:13 PM   #1
greenmk2
75 MK2 2 Door
greenmk2's Avatar
Default Ford SOHC Turbo Setup For Sale
http://cgi.ebay.com.au/ws/eBayISAPI....MESE:IT&ih=020
- FG MK1 G6ET - weekender
- Escort MK2 - Weekender
http://i76.photobucket.com/albums/j5...zaicos/Z-1.jpg
greenmk2 is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2007, 09:58 AM   #2
whooligan
whooligan's Avatar
What mods are required to the head/bottom end? ie porting, lower compression pistons etc.
Old 05-12-2007, 05:49 PM   #3
greenmk2
75 MK2 2 Door
greenmk2's Avatar
Smile
I have read that it could be laggy on a 1.8 ltr but have been told a 2ltr would be alright. I wasn't to worryed about lag issues cause i have big valves road/rally cam 25/75. bored 60 thou. The only limit would be how much the 350 holley could flow. I wanted to get around 180hp at the wheels. I have only got standard bottom end.
Here's some info:
"Mazda and Hitachi jointly developed the HT18S-2S Twin Scroll turbocharger for the 13B Turbo. This new turbocharger was designed to have virtually no " turbo lag " by having a flap that varies ( vacuum operated @ above 2500rpm ) depending on the load that opens wider during heavy load to have greater throuput and torque band. The turbo had two exhaust intakes into the turbine, the turbo acted as two turbos, by having both of advantages of small and big turbos, giving fast low end torque response and high end power. The turbine side was water cooled where the main body was cooled by a dual-ski heat shield."
Old 05-12-2007, 06:18 PM   #4
greenmk2
75 MK2 2 Door
greenmk2's Avatar
For the compression i was going to use a decompresson plate. I think a mild cam or even better still a high lift low duration cam would be good.. I never drove the car with this setup which makes it hard to say..
Old 06-12-2007, 07:31 AM   #5
whooligan
whooligan's Avatar
Sounds interesting.
I have a worked head on my pinto currently, which goes alright, but a turbo would set it off nicely. The bottom end is standard but has been balanced and bluprinted.
Would you be ok with freighting it to Melbourne? If so, I'll probably wack a bid on.
Old 06-12-2007, 04:52 PM   #6
greenmk2
75 MK2 2 Door
greenmk2's Avatar
Smile
Sounds interesting.
Yeah i reckon it would need a cam and a modified head to work at its best.. When they are on the 13B they hi-flow them and they get anything up 400hp!!
Freight to melbourne should around the $50 mark..
Old 09-12-2007, 10:56 PM   #7
EatA_VL
hey GreenMk2 was just wondering how much power would it pick up on a stock 2l and well will it be a petrol sucker, also would it be a good daily driver or is it laggy ?? and like when i mean lagg how much lagg?
cheers Mate,
Steve
EatA_VL is offline   Reply With Quote Multi-Quote with this Post
Old 10-12-2007, 12:14 PM   #8
whooligan
whooligan's Avatar
Well, I can't bid on it now....Just sold the motor I was going to put it on.
Old 10-12-2007, 06:10 PM   #9
EatA_VL
also how would i go about fitting that in a tc cortina engine bay as it looks like it steps out a bit and may run in to my master cylinder..
Old 10-12-2007, 08:44 PM   #10
greenmk2
75 MK2 2 Door
greenmk2's Avatar
Smile
i am not shore about tc cortina engine bay. It would have to be more roomy than the escorts engine bay
Old 10-12-2007, 09:17 PM   #11
EatA_VL
would i maybe have to maybe do another brake setup.
well that ok umm im only 16 and i have a stock 2l in a cortina at the moment im pulling down the engine and this came up.
i would need new springs?
and also how would it drive is there lagg? is this good for daily use ??? as im not quite with these turbo setups and for the exhuast manifold would that happan to fit a t3/t4 ??
cheers,
Steve
Old 11-12-2007, 09:44 PM   #12
greenmk2
75 MK2 2 Door
greenmk2's Avatar
The flange is a lot different to garrett type flanges. but could very easily be changed. if your driving in traffic a small t3 garrett would be sweet. if you want to go stock 2ltr just find a de-comp spacer plate with too head gaskets. and use a small turbo with low boost around 7-9psi. The top compression ring landing on the standard piston seems to collaps with to much boost.
your brake situation sounds a little tricky...
Old 11-12-2007, 10:05 PM   #13
EatA_VL
thanks for that info.. is this internally wastegated ?? and could you happan to give me a measurement as from the exhuast manifold to the turbo as then i can go from there
Cheers,
Steve
Old 12-12-2007, 05:18 PM   #14
greenmk2
75 MK2 2 Door
greenmk2's Avatar
Thumbs up
Cheers,
Steve
Its internally wastgated. Here's the measurement..
cheers jason
