#1 | |||
75 MK2 2 Door
Here's some info: "Mazda and Hitachi jointly developed the HT18S-2S Twin Scroll turbocharger for the 13B Turbo. This new turbocharger was designed to have virtually no " turbo lag " by having a flap that varies ( vacuum operated @ above 2500rpm ) depending on the load that opens wider during heavy load to have greater throuput and torque band. The turbo had two exhaust intakes into the turbine, the turbo acted as two turbos, by having both of advantages of small and big turbos, giving fast low end torque response and high end power. The turbine side was water cooled where the main body was cooled by a dual-ski heat shield."
- FG MK1 G6ET - weekender - Escort MK2 - Weekender http://i76.photobucket.com/albums/j5...zaicos/Z-1.jpg |
75 MK2 2 Door
For the compression i was going to use a decompresson plate. I think a mild cam or even better still a high lift low duration cam would be good.. I never drove the car with this setup which makes it hard to say..
Sounds interesting.
I have a worked head on my pinto currently, which goes alright, but a turbo would set it off nicely. The bottom end is standard but has been balanced and bluprinted. Would you be ok with freighting it to Melbourne? If so, I'll probably wack a bid on. |
#4 | |||
75 MK2 2 Door
![]() Freight to melbourne should around the $50 mark..
hey GreenMk2 was just wondering how much power would it pick up on a stock 2l and well will it be a petrol sucker, also would it be a good daily driver or is it laggy ?? and like when i mean lagg how much lagg?
cheers Mate, Steve |
Well, I can't bid on it now....Just sold the motor I was going to put it on.
also how would i go about fitting that in a tc cortina engine bay as it looks like it steps out a bit and may run in to my master cylinder..
