At Sea. Missing the Ts
I have a manual KH Laser. It fires up ok,it revs when I press the accelerator, my problem is it will idle ok for a bit (not long) and then stall. Do you think it could just be a timing issue or a carby issue. Another thing that might point someone in the right direction is, when it begins to stall, I cant recover by pressing the accelerator, she just stalls.
Assistance appreciated
BF FANTASY XR6T ![]() Winter White FG XR6T Ute Mods: Herrod S/S Cat Back -Chrome 18" BSA 291 (Blades) - F6 CAI, Bosch Injectors, PWR Intercooler RDP tuned. WWW.RDPMACKAY.COM.AU POLEPOSITION TRIPOD and XForce gauges The T has a new garage buddy - 2010 FG XR6T Ute |
Over Thinker
try a new fuel filter
you may have clogged jets inside the carby or the fuel pump diaphram on the carby itself needs replacing check that the dissy cap and leads are good and the spark plugs if it was timing you would have more trouble starting it
My car goes Brumm Brumm |
Problem was with the ignition module.
