ford-88
hey I've got my dash in that digital mode an its showing up no oil pressure. when i first put in digital mode a while back it worked. anyone got any ideas to wats happened
thanks |
i miss my torana!
oil pump is dead or you have no oil
ford-88
I've checked the oil its all good. how do you check if the pump has gone
i miss my torana!
ummm take off your oil cap wile the engines running and see if oils comming to the top? just guessing never tryed it but it sounds like it would work lol
Spin 'em Habib !
also check the Vaccuum Thingy on the Top of the rocker cover is on properly , and its not producing a Vaccuum Leak
AU2PWR |
#6 | |||
OK .... if you are in the diagnostic mode for the dash ... if the oil pressure section is reading 0 ... it means that it is OK.
eg: 0 = normal 1 = failed condition / warning light on So you have no issues.
ford-88
in diagnostic mode it use to show what a would guess is the oil pressure use to change readings all the time
