Old 26-10-2007, 06:38 PM   #1
Piotr
Non-Regular Member
Default Magnecor leads
Just in case anyone was thinking of changing leads. Me and Ives went to Thundercords just recently and got a set of KV85 leads made up. So if you your after a set of leads they have the measurements and can make you up a set.
Cost for the KV85 was $150
Piotr is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2007, 07:18 PM   #2
Ives
Ives's Avatar
That is competition-grade 8.5mm leads. Good stuff.
Unit 2, 20 Crescent Street,
GRANVILLE, NSW 2142
Phone: (02) 9897-3777
Conatct: Bob or Neil
Ives is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2007, 07:34 PM   #3
atec77
Did he have the Jag in at work or the Opel ?
atec77 is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2007, 08:09 PM   #4
bru20vt
Can someone explain the benefit of doing this - unless OEM failed.
dom
bru20vt is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2007, 09:16 PM   #5
Ives
Ives's Avatar
Yes, I noticed a silver Jaguar... is it yours? what's the story?
More efficient and/or smoother ignition? Good ignition leads are good compliment to good aftermarket spark plugs.
Old 26-10-2007, 10:46 PM   #6
Piotr
Non-Regular Member
I know on the WP and maybe WQ the stock plugs and leads are prone to rusting caused by sitting water (There is a thread about it somewhere). My leads on cylinder 3 and 4 had this rust and I have noticed the car runs smoother especially above 4k rpm.
Old 27-10-2007, 07:58 AM   #7
melbzetec
Old enough to know better
melbzetec's Avatar
I swear by them. Good stuff guys. Did you get red or blue?
Piotr, sounding like the Fiesta is getting some very smooth upgrades(eg suspension etc)...what else are you up to?
Manual 2003 Machine Silver 5 Door LR Focus Zetec.
Mods: Ford Racing CNC'd cylinder head milled .040", 3 angle valve grind. Ford Racing Stage II camshafts. Ford Racing cam gears. Ford Racing long tube header. Random Technology hi flow cat. Herrod 2.25" stainless cat-back. Pipercross Viper intake. CFM 65mm throttle body. 2000 ported intake manifold. Herrod Custom SCT tune. Eibach suspension. Quaife ATB diff. Wilwood 13" brakes. Custom ST170 leather interior.
www.cardomain.com/ride/2773918
melbzetec is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2007, 08:57 AM   #8
Ives
Ives's Avatar
We got the red (racewires) ones. The blue is Electrosport 8mm, and black is 7mm.
