Old 19-06-2007, 07:46 PM   #1
ford-freak
Default Need Help With Tc Cortina Wheels
Can Anyone Help With Wheels & Tyres To Fit A 73 Tc Cortina . Need To Know How Big Can I Go (size & Width) What Pcd, What Offset, Etc. Everything Is Std But Will Be Fitting Lowered Springs/shocks. Sick Of Being Offered Superlites. Please Help !!!!!!!
ford-freak is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2007, 11:37 PM   #2
EviLkarL
Ausfactor.com
EviLkarL's Avatar
Size of wheel would depend on hoe much you are prepared to lower it. 18" is not out of the question however you will have trouble on the front.
Width is the biggest problem if your using the standard diff. probably 8" are not out the the question with a 4.5" in / 3.5 out.
Few guys over at the Cortina Forums have fitted shortened 9" diffs and mini tubs and run 9" with a good offset. Its all about $$$$$ and your interest in keeping the cars chassis original or not
Personally I'm running standard Focus wheels on mine at the moment, 15/7" and they are great for my requirements. Car is lowered about 3 inches but apart from that all original. Cutting anything such as the underbody or tubs is out of the question, however a 9" might be a good upgrade one day.
EviLkarL is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2007, 02:03 AM   #3
Cologne Ghia
Cologne Ghia's Avatar
at the front - if you grind away the wheelarch inner lip - much wider and larger wheels can be used
Cologne Ghia is offline   Reply With Quote Multi-Quote with this Post
