Old 20-05-2007, 08:33 PM   #1
melbzetec
Old enough to know better
melbzetec's Avatar
Default LR Clutch advice
Well, I think my clutch is on the way out. Started slipping in 5th gear today along the freeway (accelerate in 5th and it starts slipping). Not dead yet, but the writing is on the wall
Adam and Matt, from memory you've both replaced your clutches.
Any tips from anyone? eg Stay genuine? Aftermarket? Best options? Things to look out for? etc etc
Manual 2003 Machine Silver 5 Door LR Focus Zetec.
Mods: Ford Racing CNC'd cylinder head milled .040", 3 angle valve grind. Ford Racing Stage II camshafts. Ford Racing cam gears. Ford Racing long tube header. Random Technology hi flow cat. Herrod 2.25" stainless cat-back. Pipercross Viper intake. CFM 65mm throttle body. 2000 ported intake manifold. Herrod Custom SCT tune. Eibach suspension. Quaife ATB diff. Wilwood 13" brakes. Custom ST170 leather interior.
www.cardomain.com/ride/2773918
melbzetec is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2007, 12:12 AM   #2
WRC1AB
WRC1AB
WRC1AB's Avatar
Aftermarket option:
http://replacement.autopartswarehouse.com/parts
Most Ford Focus clutch kit options are listed here.
This should give you some idea.Personally I haven`t changed my clutch yet and I`m close to 90 000km.
[ :eclipsee_ : :eclipsee_ LR Focus
WRC1AB is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2007, 05:17 PM   #3
FRA
Mr Focus
FRA's Avatar
Well Ford Racing has Original equipment and aftermarket parts.
Not sure how long Ford Racing will keep making Zetec parts for.
Cosworth: 2.5" high flow exhaust system, piston & rod 8.5.1 Ford Racing: Tail lights, engine cover, racing wing, cnc'd head, manifold, 70mm tb. Lentech: Torque Convertors with 23 spline input shaft, valvebody
Oz racing: WRC OBX: 4-2-1 race header
SCT: xcal3, dash scan.
FRA is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2007, 05:29 PM   #4
FOCUSonTHIS
FOCUSonTHIS's Avatar
Steve my clutch only when because the clutch springs went on me. Other than that I had plenty of meat left on the clutch. I don't mind the orginal clutch. Should've went aftermarket heavy duty clutch. It would probably be cheaper but the original is good. Shop around and see what you can get for the price. A thing I hate about my car is the noisy thrust bearing and costs $130 if i remember correctly for that. So get that checked as well Steve.
2015 MK7 VW GOLF GTI
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
FOCUSonTHIS is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2007, 11:51 PM   #5
zetec
Zoom Zoom
zetec's Avatar
My clutch went after I taught a girl to drive. Never again. Original clutch not an issue, it's not like I do burnouts anyway.
2012 Mazda3 MPS
Old 22-05-2007, 06:15 AM   #6
FRA
Mr Focus
FRA's Avatar
Did she drop your gear box on the road...TeeHee
Old 22-05-2007, 08:12 AM   #7
melbzetec
melbzetec's Avatar
Are you saying I drive like a girl Matt??!! LOL
Old 13-06-2007, 06:26 PM   #8
melbzetec
melbzetec's Avatar
OK guys. I have a choice.
Motorcraft clutch kit fitted by Ford Dealer. approx $1200 + (could be more depending on how much machining needed on flywheel)
Exedy clutch fitted by ABS in Moorabbin. $1211.Includes machining
Any advice?
Old 13-06-2007, 06:35 PM   #9
FRA
Mr Focus
FRA's Avatar
Don't you want a Windsor centerforce clutch kit?
Old 13-06-2007, 07:57 PM   #10
photn
AFF Post NAZI
photn's Avatar
Go the ford steve... that way if it stuffs up then Ford are to blame and they cant do anything about it.....
Old 15-06-2007, 12:45 AM   #11
Zetec20
Zetec20's Avatar
exedy clutches are really good, i used to have one on my old car, if you can install it yourself or know someone that can to drop the price becausethe cost price wouldn't be over the $400 mark for the parts
: Don't yell, i'm probably hungover
Zetec20 is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2007, 09:45 PM   #12
FOCUSonTHIS
Machine costs about $40 thats how much I paid for mine when I got it done.
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
