Old 23-03-2007, 01:30 AM   #1
oysta
Escort MkII 1977 2.0L
Default MKII steering noise?
Hi all,
My MKII Escort is making some unattractive noises when i corner (actually when i turn the steering wheel), not always but fairly regulary. The noise is a sort of crunch/thud deeper sound and I can feel it feed back through the steering wheel.
Is this a common problem? Could it be the rack mount bushes or the rack itself, or perhaps something else.
Any help appreciated.
Thanks.
Adam.
oysta is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2007, 10:41 AM   #2
monkeydog
Shift for brains
Mine does something similar to this in the left, so far it has been traced to the springs turning building up pressure and then releasing it's load.
monkeydog is offline   Reply With Quote Multi-Quote with this Post
Old 27-03-2007, 11:06 AM   #3
EvilEsky
Bulid: Escort 79 MK2
EvilEsky's Avatar
i Think ur rack is gonna go! take it to a shop and ask em what they think.
:eclipsee_ Current Bulid: 1979 MK2 Escort- 2 Door, Maunal, 1.6- :sm_headba
EvilEsky is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2007, 07:45 PM   #4
DaveyB
DaveyB's Avatar
Theres a plastic bush inside each end of the rack that can break up & cause vibration when loaded up under cornering - could be that - had it go on my old RS2000. The more cornering load the worse the noise& vibration. Can be repaired - just means pulling the rack internals to bits....
DaveyB is offline   Reply With Quote Multi-Quote with this Post
