Old 17-01-2007, 09:09 AM   #1
fpv_escort
Default Mk2 struts
Hi
Looking at putting Mk2 struts in a mk1 track day car. If we were to use mk2 struts would we need the mk2 control arms, crossmember and are the brakes a lot bigger??
Thanks
fpv_escort is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2007, 12:37 PM   #2
dirty hands
Over Thinker
dirty hands's Avatar
dont know about the wheel alignment problems
the ratio might be better in the rack and pinion
the lower ball joint looked the same in the MK 1 as the mark 2 to me
sounds like a very good mod
My car goes Brumm Brumm
dirty hands is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2007, 02:20 PM   #3
73escort
73escort's Avatar
i believe the ball joints are actually a different size..
if its for a track car try getting a set of complete capri sttruts,
bigger brakes and larger diameter post, these will fit straight into a mk1
The Toys
Daily - Mk1 Escort Panel Van - 2litre converted, re-trimmed interior, 4.11 diff, 4spd,
In the build - Mk1 escort 4dr, 2lt Pinto,
73escort is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2007, 05:18 PM   #4
eski666
eski666's Avatar
I put mk2 struts on my mk1 and there was no dramas. The only hard part was trying to find a set of mk2 struts!!
eski666 is offline   Reply With Quote Multi-Quote with this Post
