ok, i was trying to hook up a neon to the bootlight which was successful it all worked fine, then i thought id try for a second but obviously it tried to draw to much power and blew something somewhere and i had a look at the manual as to which fuse it would be and couldnt find any thing so ive got no idea wat i have done
Ford Forever! Lowndes Is No.1 |
Spin 'em Habib !
soooo is anything wrong with the car , all the gauges work , Accessories Lights Radio , Fans , High Beams ,
AU2PWR |
FTF Club Moderator
If it is a fuse, it is where your right knee is, when you sit in the drivers seat. Just pull the cover. Now the inside light fuse is a red one (10 amp) and is located in the top right hand corner of the fuse box.
Albert Einstein: Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom. (It is more difficult to alter a preconception than split an atom) Falcon Tickford FPV (FTF) Car Club of NSW Fords in the Park 2010 I use and recommend Stingray Car Security. http://www.stingraycar.com.au/ |
everything else works except the bootlight..
not here much anymore
it will more than likely be your interior light fuse, theyre all listed in the manual. just go through them one by one and you will find the blown one.
RAM 1500
Looks like you have fuse no.10 and fuse no.11
5 amp and 15 amp Otherwise you might have stuffed up somewhere mate and grounded it without blowing a fuse. |
