i wanna fix up the "6" on the boot as it is not lined up with "XR" correctly...how do i get it off gently without me scratching the paint and putting back on and making sure it stays on. also what do you need to make it stay once you put it back on.
thanks |
#2 | |||
Merry Xmas To All
Does anyone know of a template available to re-fit the XR6/8 badges acurately? I still havent put mine back on yet, as I forgot to make a rough template before I took them off. ANy help HUGELY appreciated on this one!
#4 | |||
Merry Xmas To All
i work in a panel shop... IM a beater by trade! So sad! Someone help me!
Spin 'em Habib !
Lucky the SR Badges are Stickers , A Bit of Heat , and there off , Like a Zirtec !
AU2PWR |
AU2 XR8
eucalyptus oil works a treat put some on the top off the space between the badge and the panel go away for a few minutes and pull it off more often than not the badge has already fallen off anyway
not here much anymore
No real "template" as such, even in the factory they were literally just slapped on by hand, which accounts for why some of them just look ridiculous.
The badges come up on Ebay all the time, they arent cheap from Ford though - the "8" from XR8 is around $20 on its own ![]() Easiest way to line them up is to use a ruler and a steady hand. Ive done mine differently at the back and also cleaned up the position of my Tickford wings.
RAM 1500
_Oo===oO_
I'd take measurements off one of the side XR6 badges as a reference for the boot.
COURAGE - ENDURANCE - MATESHIP - SACRIFICE
we usually use masking tape to makr distance from gaurd edge, or from the repeater lamp or someting similar and just cut the tape around the badges so they can be returned to an exact location. I just frgot to do mine, and we havent had Au XR6 or 8 come in since!
