Old 08-11-2006, 07:56 PM   #1
JoesAu
JoesAu's Avatar
Default Idle puff of black smoke
On startup during first 30 seconds of idle my car dumps thick black smokey stuff for bout 8 seconds, then it revs a little and stops?? what is it?? its been like this for a while. Its so thick i reckon my exhaust would be clooged up with this s h i t....
JoesAu is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2006, 09:36 PM   #2
needaXYGT
AU II XR8
needaXYGT's Avatar
cant realy help you but i would get the exhaust looked at.
needaXYGT is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2006, 10:02 PM   #3
JoesAu
JoesAu's Avatar
the exhaust, would'it be the engine???
Old 08-11-2006, 10:02 PM   #4
JoesAu
JoesAu's Avatar
its doesnt reaLLY chew threw oil either. Icant really remember how it started, i changed my full exhaust, intake, and throttle body and after that i guess it started. Its weird,
Old 08-11-2006, 10:03 PM   #5
bodes-sh
lol, yes it would be, how long since your last oil change? does it do it when hot or cold or both?
Old 08-11-2006, 10:03 PM   #6
Kryton
Kryton's Avatar
sounds like the valves may need a look at.
could be that the valve seats have worn.
Old 08-11-2006, 10:06 PM   #7
JoesAu
JoesAu's Avatar
so i rip the cover off the head yeah?? my oil smells like fuel a bit.
Old 08-11-2006, 10:06 PM   #8
JoesAu
JoesAu's Avatar
it does it both hot and cold.
Old 08-11-2006, 10:07 PM   #9
bodes-sh
i had an ea a couple of years ago that did a similar thing, mind you that had 280,000+ kms on it so it seems strange that yours is doing it now...has the oil been changed regularly?
to replace valves or at least look at them you have to pull the head off the car, which is a real pita....
Old 08-11-2006, 10:09 PM   #10
Kryton
Kryton's Avatar
just take it to a mechanic or get a service repair book from Autobarn.
if you dont know what your doing and you cant get anyone to help you that does know what they are doing then see a mechanic about it.
Old 08-11-2006, 10:18 PM   #11
JoesAu
JoesAu's Avatar
Pain the a s s. i reckon it would be air fuel ratio, and it burns the excess fuel. I change my oil occassionally, i use Magnatec. Ive had the car for 25000km's and changed the oil 3-4 times.Very strange one.
Old 08-11-2006, 10:21 PM   #12
JoesAu
JoesAu's Avatar
it never used to do it thou??
Old 08-11-2006, 10:59 PM   #13
mik
mik's Avatar
the service idea sounds good, first things i would check are the plugs the air filter it cost nothing too look, then go from there
Old 09-11-2006, 12:41 AM   #14
NeishaXR8_347
SS Grunt
NeishaXR8_347's Avatar
The problem your having is its running rich when cold that is all, it could possibly be that your oxygen sensor is not working and is basically telling the car it needs more fuel when it doesnt.
The engine oil smelling like fuel is a dead give away that its overfueling and nothing else. It is basically pumping in so much unwanted fuel that its passing the rings and into the crankcase. This is a problem in itself with so much fuel in there and not needing it it washes away all the oil in the bores and will eventually glase the bores up and will start to use oil. Thats my Opinion.
Shaun.
The Beast has gone to a new home
Morpheous VE SS 6LTR 6speed Manual in its place, Leather, Lowered, 20's, Ramjet OTR and Dual 3inch, 280RWKW
I will also enter any part of the Forum I wish to enter. :
NeishaXR8_347 is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2006, 04:17 PM   #15
WhiteKnight
Another possiblilty could be at least one injector leaking slightly while the engine is not being used but while residual pressure remains in the fuel lines. This would cause a build up of fuel in the manifold/engine for the next cold start.
--- Just another thought,hope it may help.
WhiteKnight is online now   Reply With Quote Multi-Quote with this Post
Old 09-11-2006, 05:31 PM   #16
JoesAu
JoesAu's Avatar
yeah i might change the oxy, i cleaned it a while ago and it seem to stop it a bit, and i got 50 km's extra out of a tank as well.
