With da Warlords
Does anyone know how to remove the ECU from an AU?
I need the numbers that are apparently ontop of the ECU next to the plugs, so that I can give them to spiro for my flash tuner. The problem is the stupid bracket that holds the ECU in place. Its pop riveted or something to the chasis of the car & I can't remove it to get the ECU out. I nearly destroyed the ECU & Bracket on the weekend trying to get it out, I got that mad at it, I had the angle grinder plugged in rdy to go, wussed out at the last second.
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear. For Sale: Parachute. Only used once, never opened, small stain. Windsor Warlords AU III XR-8220 ![]() ![]() XR50T Ute - 300rwkw (give or take depending on the day)
drill out the pop rivet and use a bolt to replace it. Thats what i did and mines fine.
With da Warlords
I tryed drilling it out, need to sharpen the bits i think. I'll have another go.
Any other ideas?
![]() Join Date: Jan 2005
Try the angle grinder on the pop rivet. You need to remove that rivet to get the bracket off.
The ECU code is a sticker stuck to the bottom, so if you can see the sticker without removing the bracket, rip it off, get the code, and stick it back on with some packing tape or something.
if you feel brave enough, you could try a hamer and chisel to chop it off...
:D:D
or u can just remove the head of the pop rivet and then take the bracket out then as said use balts
#7 | |||
With da Warlords
1R23-JB --------- NPEF 12JB-------------109262
#8 | |||
With da Warlords
fair enough....hacksaw anyone?
#10 | |||
With da Warlords
ssssshhhhhhhhhiiiiiiiiiiiiiiiiiiiiiiiiittttttttttt tttttttttt!!!!!!!!!!!!!!!!!!
Use a hacksaw slice a groove n use a flat blade.
Anthony |
#13 | ||
or take it to your nearest ford dealer & tell them to check it for you with the WDS it will only take 5 minutes.
#14 | ||
With da Warlords
yeah, thats what I did in the end. Cost me $50 bucks, they will get the strategy code & any others stored in the ECU for me while i'm there. Booked in for 10am.
My car had better come back with no probs though. Every time I take a car to ford it comes back with another problem that will just mysteriously appear lol.
