Old 02-06-2013, 05:14 PM   #1
Radicool
Default Ford Festiva Power Steering Noise
I own a 1999 Ford Festiva. Since I bought it off my brother it has always made a loud yearning sort of noise when you steer the wheel. It only occurs if you turn from parking or going around tight corners. I also noticed the wheel is a little hard to turn. However, I'm only comparing that to my parents Honda Jazz. Im unaware of how a normal car's turning should feel.
I have heard Ford use cheap plastics in some of the power steering parts which are prone to breaking. This IS NOT a power steering fluid problem. I have already flushed out the fluid and replaced with new fluid with no success. Wondering if anybody experienced the same problem and has a solution.
Note: I have already tried flushing out the power steering fluid. That is not the problem.
Radicool is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2013, 12:13 AM   #2
Radicool
Default Re: Ford Festiva Power Steering Noise
bump.
Old 07-06-2013, 12:23 AM   #3
Pursya
Would look at the drive shafts.
Certainly make a noise when steering if they need replacing.
As your vehicle is 15 years old it is a likely suspect.
Don't take it to a mechanic, take it to a front end specialist.
Pursya is offline   Reply With Quote Multi-Quote with this Post
