Old 28-05-2013, 09:55 PM   #1
crispy79
crispy79's Avatar
Default mk2 cortina/ escort struts
Hi guys
looking to upgrade my calipers on my mk2 Cortina.
Are then mk2 Cortina struts brake mounts the same as the mk2 onwards escort?
Also looking at some of the wilwood kits available out of pommy land, would like to get a hold of there adapters they use to fit the larger spacing wildwood calipers
like these
http://www.burtonpower.com/parts-by-...8726-m16m.html
would much prefer to buy local if possible
can anyone point me in the right direction
Thanks
mk2 cortina, 2v clevo power, in build (still)
This argument that you are carrying on with is akin to shuffling deckcahirs on the Titanic.
crispy79 is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2013, 10:54 PM   #2
RSgerry
Well hello Mr Fancypants
RSgerry's Avatar
Default Re: mk2 cortina/ escort struts
Hi crispy
From what I hear, the MK2 Escort brakes will go on the MK2 Tina struts as this is what I am doing on my Anglia. The standard Girling M16 calipers with discs and pads apparently do an excellent job. This is the set up on my RS (vented discs) and they are great. Be careful on which Willwood calipers you go for as some are rated to 600 or so kg. Additionally, I have read that the Willwood contact surface isn't always as high as the M16s. Have a look at this thread for lots of info to confuse you even more. I am a bit lost with it all myself.
http://105speed.hyperboards.com/acti...topic_id/12973
Whilst it is an Anglia forum, they are talking about MK2 Tina struts (mostly).
Let us know how you get on.
Gerard
1965 Ford Anglia
1980 Ford Escort RS2000
2006 Mazda SP23
2012 Ford Focus ST
RSgerry is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2013, 10:37 PM   #3
tickford2001
There is a Volvo 4 pot caliper that is a fairly common conversion on early escort/cortina models. You can run a vented rotor with this setup also.
tickford2001 is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2013, 10:53 PM   #4
jpblue1000
jpblue1000's Avatar
Australian delivered Mk2 escort struts
Volvo 4 piston calipers on Mk2 Struts with bmw e30 disk
Ap racing 305mm disk
jp
jpblue1000 is offline   Reply With Quote Multi-Quote with this Post
