03-06-2008, 08:58 AM | #1 | ||
I've done a search and still need help.
My AU XR8 S 3 has a flat battery. Can I just remove it and recharge it (takes 8 hours). Would there be a problem if I do this with the ECU etc? I suppose (given that it is flat) I cant connect the battery charger to the terminals while it is still connected to the car and charge it that way Also I have heard that sometimes you can use a 9 volt battery plugged into the cigarette lighter so that the radio code is not lost. How is this configured, wired etc? Last edited by sednwol; 03-06-2008 at 09:11 AM. |
03-06-2008, 09:14 AM | #2 | ||
With da Warlords
Don't worry about the ECU, It will relearn over time with your freshly charged battery.
You can charge it while it's connected to the car. Positive lead onto positive battery terminal, Negative lead onto a good earth in your engine bay somewhere and you'll be set.
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear. For Sale: Parachute. Only used once, never opened, small stain. Windsor Warlords AU III XR-8220 300+ rwhp of Manual fun XR50T Ute - 300rwkw (give or take depending on the day)
03-06-2008, 09:18 AM | #3 | |||
03-06-2008, 09:21 AM | #4 | |||
With da Warlords
Yes mate. Nearly every month, cause I never drive my car. Not dangerous at all. Just make sure you DON'T PUT the negative onto the battery, make sure it goes to a good earth, eg. Alternator bracket, Manifiold etc
03-06-2008, 09:31 AM | #5 | |||
03-06-2008, 09:41 AM | #6 | ||
With da Warlords
1 - Positive lead onto positive terminal on battery
2 - Negative lead onto earth. In my XR I use the alternator bracket, or hook onto the manifold, or engine lift point thingmajig. Picture below 3 - Plug battery charger in, and away you go :-)
03-06-2008, 09:45 AM | #7 | ||
I'll try connecting it to one of the brackets that hold the exhaust pipes in place.
03-06-2008, 09:49 AM | #8 | ||
With da Warlords
Any solidly connected metal object under the bonnet will do just fine as a earth. so find one and take your pick
03-06-2008, 09:52 AM | #9 | ||
Sorry to be a pain, what if I connect the negative to the bonnet, where the catch is. its all metal? Thanks for all your help
03-06-2008, 09:57 AM | #10 | ||
With da Warlords
Nah probably not good enough. If the earth is crappy, it just won't charge.
Use the alternator bracket if you have one, or the top of your manifold, or that little thing in the picture above. Any solid unpainted metal will do fine.
03-06-2008, 09:58 AM | #11 | ||
Thanks, I'll use the engine lift as you first suggested.
03-06-2008, 09:59 AM | #12 | |||
JMM modded EF
why cant you connect it to the negative terminal? i used to all the time on my ef and never had any troubles. also i grew up with batteries dads dad started the business, now dad and i run it, and i have never heard this.
"She goes like a zirtek" WANT A FAST FORD RING THIS BLOKE V V Abbott Engines for HeadWork 20 years experience PH Rob on (07) 5526 3883
03-06-2008, 10:04 AM | #13 | ||
With da Warlords
Another piccy for ya
03-06-2008, 10:10 AM | #14 | ||
Thanks James, I've connected it to the engine lift thingo and my battery charger is showing the battery flat and I have a good charge connection. Many thank again really appreciate you help mate!
BTW who signed the engine cowling? |
03-06-2008, 10:19 AM | #15 | ||
With da Warlords
Dick Johnson, hehe.
Glad to be some help. 8 - 10 hours and you'll be all good. Theres also a good chance you didn't lose ECU settings if you never disconnected your battery, unless it was REALLY dead. Either way though, it won't cause any probs for ya.
03-06-2008, 10:24 AM | #16 | ||
She wasn't completly flat, everything working horn etc, just wouldn't turn that big baby over LOL.
03-06-2008, 10:28 AM | #17 | |||
With da Warlords
If charging out of the car, they state Negative to negative of course, because theres no other way to get a circuit when its not connected. Heres a link to a manual stating what I said above, and some text I have copied out. http://209.85.173.104/search?q=cache...ient=firefox-a STEP 2B - CONNECTION IN VEHICLE Determine if the vehicle is Positively (+) or Negatively (-) earthed. Negatively earthed vehicles have a cable (usually black) from the Negative battery terminal to the vehicle’s chassis. Negatively earthed (Most Vehicles) Connect the RED lead (battery clip) from the charger to the Positive (+) battery terminal. Connect the BLACK lead (battery clip) from the charger to the vehicle’s chassis away from the fuel line or moving parts.
03-06-2008, 10:33 AM | #18 | ||
With da Warlords
P.S - Page 7 in that link above is where the info is.
You can clearly see that there is a different procedure for in car and out of car charging.
03-06-2008, 10:34 AM | #19 | ||
Sales Representative
woops... disreguard and delete please mods
Project InfernoSR - Back Burner Project FeralTerra - No longer Project Fairmont Prodigy - Sold Thanks go to: MY WIFE! Bathurst Brakepro Undacar eBay!! |
03-06-2008, 10:39 AM | #20 | ||
The way James describes works as I am getting a connection and therefore a charge.
03-06-2008, 10:44 AM | #21 | ||
With da Warlords
read above lol
woops adam caught on lol
03-06-2008, 10:49 AM | #22 | ||
James should it be connected to the battery post (if possible) or just onto the red lead fitted to the post.
03-06-2008, 10:49 AM | #23 | ||
With da Warlords
Some for disconnecting, as you can see in car charging says remove from vehicle chasis
"Quote from page 9 above link' STEP 6 - DISCONNECTION. Turn the 240V mains power off. Battery out of vehicle Remove the BLACK lead (battery clip) from the battery. Remove the RED lead (battery clip) from the battery. Battery in vehicle Remove the chassis connection. Remove the battery terminal connection
03-06-2008, 10:51 AM | #24 | |||
With da Warlords
03-06-2008, 10:58 AM | #25 | ||
Just wondering as Iam not hearing any battery "bubling" noise that I usually hear when charging...I'll just wait and see. My charger shows only lit boxes showing the state of charge ie flat, 25%, 50% etc, it doesn't actually tell me if it is charging. Still showing flat.
03-06-2008, 11:19 AM | #26 | ||
Afterburner + skids =
Well if you only connected it half an hour ago, chances are the battery is still flat!
03-06-2008, 11:34 AM | #27 | |||
03-06-2008, 11:41 AM | #28 | |||
JMM modded EF
dont worry bout battery bubbling
03-06-2008, 11:43 AM | #29 | ||||
JMM modded EF
if a battery bubbles only in one cell the chances are that cell has collapsed. easy way to tell if battery has dropped a cell: each cell is rated at 2.0-2.2 volts thus if a cell drops in a 12 v battery the battery when charged will drop down to 10 volts approx
03-06-2008, 11:57 AM | #30 | |||
