30-08-2006, 01:59 AM | #1 | ||
I've just bought a 1990 kh laser (manual, gl 1.6) from a dealer with a months rego. This is not something I would normally do but I was pretty desperate for a small car and the price was right. Body has no rust, the interior is nice and it's a very smooth feeling car. Plus it's about twice as good on fuel economy as my old van which I will continue to use once repaired (the reason for getting the laser).
There are a few problems with it and I'd like a bit of input on them if anyone would be so kind. It has to pass rego on the 24th. I've never been to fond of going to a mechanic but I will if I have to. I haven't really looked into any of these problems yet but I'm sure some are easier to fix than others. My mechanical abilities are better than basic but not up to the full engine rebuild level (I've tried it once - not worth the time and effort). The temperature guage is all over the place - I'm thinking it's a loose connection. It reads when still, but the slightest movement bounces the needle between reading and nothing. The highbeam control doesn't work - works for momentary (lever towards me) but normal highbeam doesn't work (something wrong in the control stick). The interior fan doesn't work. Now the big problem. There is a very slight oil leak on the joint between the engine and the gearbox, right at the bottom of the engine. It isn't a big problem but I need to fix it to pass rego. I've attempted the basic stop leak type stuff and it has no effect. Is there a quick and dirty method (aryldite?) that will keep the oil leak in check without actually replacing the seal? If not, what would this be likely to cost me to get fixed? (I could attempt it myself but I can't see that happening with my current scedule). If anyone can give me an idea of any of these problems it would be much appreciated. Thanks |
30-08-2006, 03:05 AM | #2 | ||
Over Thinker
any good mechanic will spot a cover up anyway
a day before inspection fill in behind the clutch/flywheel inspection plate with kitty litter or similar oil soakage product then seal up the inspection plate with sellys black silicon gasket maker clean it up so no silicon is visable (this wont stop the leak) hope you dont have broken engine mounts or torn CV boots or other problems To fix properly for a mechanic to do this its gearbox out and fit new rear engine seal ( $400 at a quess /a days work ) interior fan problem maybe a resistor or a fuse high/ low beam switch will need a second hand unit from a wrecker temp guage is as you suggest a dry solder join broken wire or a faulty sender unit in the instrument panel you can buy a cheap temp guage/sender from any auto supply shop
My car goes Brumm Brumm |
30-08-2006, 08:38 AM | #3 | ||
I won't worry about the kitty litter / gasket maker idea - I was wondering if there was a fix available, not interested in a coverup. (there isn't much oil - but I want to get it fixed - I don't want to go through the same coverup every year).
I'll be checking most of the things this weekend (I can't see not being able to fix any of the problems short of the rear engine seal), I only spent $900 on the car so $400 odd dollars sounds doable for a proper fix. Can anyone recommend a reliable and not overpriced mechanic in either the petersham, lane cove or lower blue mountains areas of Sydney? |
