Go Back   Australian Ford Forums > Club and Speciality Forums > Ford Car Clubs > F6 Owners Club of Australia
Old 26-01-2010, 08:40 PM   #1
IQUIK6
IQUIK6's Avatar
Default Hi Guys anyone able to help with dtc problem codes for livewire...
Last night my engine light came on and i had two codes teh one i cant figure out what it is is U2514... can anyone please tell me what this porblem code is referring to...
IQUIK6 is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2010, 05:40 PM   #2
XRQTR
TBA Customs
XRQTR's Avatar
Might be best to contact one of the tuners bud, they would no doubt have an answer for you.
XRQTR is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2010, 01:19 AM   #3
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
Anyone know the answer to this? I have it as well
I cant find it in the manual
Jastel is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2010, 01:40 AM   #4
burnz
VFII SS UTE
burnz's Avatar
speed sensor missing.
http://www.cardiagnostics.be/wds2000...le%20codes.htm
I don't often hear the sound of a screaming LSX.
But when I do, So do the neighbours..
GO SOUTHS
burnz is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2010, 03:16 AM   #5
FORCED F6
VIC The Place to Boost
FORCED F6's Avatar
Just go to clear DTC and it should clear it mate...
F6 310 - Blue Power Racing Developments
FORCED F6 is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2010, 10:30 AM   #6
russellw
russellw's Avatar
DTC: U2514
Description: Message for VSS missing
Electrical: Damaged wiring or connections between the VSS and PCM.
Other: Error on the SCP system between the VSS, PCM, IC and DLC Incorrect VID programmed in to PCM. PCM, IC, ABS not running current software and calibrations.
I don't know why people don't use the resources we provide here where you can look then up.
Russ
Old 18-03-2010, 01:49 PM   #7
GT450
It just may be that some people are not aware of what is available and need guidance don't you think?? It always pays to at least ask.
GT 450
GT450 is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2010, 10:29 PM   #8
Jastel
I did find your link eventually Russ thanks
But when I typed in U2514 in search all I got was this thread so I started here
Code was cleared and hasn't come back
Old 19-03-2010, 12:50 AM   #9
IQUIK6
IQUIK6's Avatar
guys i have another code that come up its p1000 whats this mean...
Old 19-03-2010, 01:42 AM   #10
russellw
russellw's Avatar
DTC # P1000
Description: Monitor Testing Not Complete
Mechanical: The on board diagnostic II (OBD II) monitors are performed during the OBD II Drive Cycle. The DTC will be stored in continuous memory if any of the OBD II monitors do not complete.
Sensor: *Vehicle is new from the factory *Battery or PCM had recently been disconnected *An OBD II monitor failure had occurred before completion of an OBD II drive cycle *PCM DTCs have recently been cleared with a scan tool *PTO circuit is shorted to VPWR or B+ or PTO is on during testing
Electrical: The DTC does not need to be cleared from the PCM except to pass an inspection/maintenance test.
Go to our DTC Reference Search and select a model and enter a code. If you don't find it under the model use the REF model option as it uses the OBD Reference table as a secondary look up.
Russ
Old 22-03-2010, 12:14 AM   #11
IQUIK6
IQUIK6's Avatar
thanks russel you have been a great help
Old 27-10-2014, 04:55 PM   #12
Sunail
Default Re: Hi Guys anyone able to help with u2514 code for ford territory
Ford territory 2005 is giving error code u2514. Can someone tell me how to resolve
Regards
Sunail
0477896997
Sunail is offline   Reply With Quote Multi-Quote with this Post
