05-06-2022, 07:30 AM | #1 | ||
Hi guys ive just brought an au2 xr8 that blows brake fuses as soon as I put them in.Ive also noticed the light switch on the dash can fully rotate .Does anyone know if they are linked or do I have 2 seperate faults. Thanks for any help
05-06-2022, 08:38 AM | #2 | ||
The lights & brakes are on separate circuits.
As an example the brakes illuminate regardless if the lights are on or off. |
05-06-2022, 11:10 AM | #3 | ||
As noted they are separate issues. Blowing the fuse immediately will indicate a short to ground most likely but can also be caused by a bulb so replace them anyway as a starting point and then check the wiring at the bulb holders for damage.
