Old 18-04-2023, 02:29 PM   #1
AU2S Rick
Slow Sleeper
Default Lsd rebuild
G'day all my first posting. I got a 3.45 lsd centre out of a Fairlane (IRS) gonna put it in my S spec au2. Are rebuild kits available. I have looked around several websites with not much luck, any help will be greatly appreciated.
Cheers Rick
Slow build sleeper
AU2S Rick is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2023, 05:12 PM   #2
asimplelife
mechanical novice hopeful
Default Re: Lsd rebuild
Sorry but I know nothing about diff rebuilds other than I will likely need one one day.
But this thread seems to have been created for your purpose?
https://www.fordforums.com.au/showth...t=diff+rebuild
And even if your kit isn't listed on ebay, maybe one of these reputable sellers can provide it?
https://www.ebay.com.au/sch/i.html?_...lcon&_osacat=0
asimplelife is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2023, 08:51 PM   #3
AU2S Rick
Slow Sleeper
Thanks for the reply. With looking through ebay and other online stores, they have no listing's for a lsd.
I am trying to get a repair kit that comes with replacement wear disc (I think that's what they are called) to do a full rebuild.
Hopefully, someone can help me
Old 23-04-2023, 09:26 PM   #4
Is it an M78 centre?
Old 24-04-2023, 08:34 PM   #5
AU2S Rick
Slow Sleeper
Smile Re: Lsd rebuild
I am not sure sorry, tried to look at sticker but most of it was missing.
It was in a series 2 Fairlane with IRS, the lsd tag was still attached
car looked a bit ruff which is why I'm trying to find the rebuild kit.
Read lots of threads here telling me I can go irs to beam just not the other way around.
I currently have 3.23 beam with noisy bearing and leaking pinion.
Glad My lad is apprentice lv mech
Old 20-05-2023, 08:59 AM   #6
Magee
Magee's Avatar
Not sure if your question is for rebuilding the LSD center or the entire cradle with suspension.
If it's for LSD center I had the same issue when I enquired about rebuilding the LSD as the clutch packs were not available. I was recommend to have a positrac centre fitted. They also said if the crown wheel and pinion needed replacing the total cost of a full rebuild by them would be $3600.
I ended up getting a 2nd hand single spinner complete diff for $250 and fitting it myself.
Magee is offline   Reply With Quote Multi-Quote with this Post
Old 24-05-2023, 08:19 PM   #7
AU2S Rick
Slow Sleeper
Angry Re: Lsd rebuild
G'day Magee,
Thanks for the reply. Yes I wanted to rebuild the diff centre only.
I have been told the diffs are not serviceable and your comment just confirmed it
Really disappointing as I got lsd centre for $50
Might try and get another 3.23 beam, do the bearings and try the centre
I can only live and learn. Thanks again
