Old 17-06-2006, 08:51 PM   #1
$90esky
Hiding in wheel smoke
Default Coolant bleed screw
Hey I want to change the radiator hoses and coolant and was wondering where I can locate the air bleed screw?
P.S: Waiting for the manual to arrive so I don't have to ask silly questions :P
$90esky is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2006, 11:59 AM   #2
T3man
T3man's Avatar
As long as the thermostat has a bleed hole in it you don't need to worry. Just fill her up - start her up - and let it run for ten minutes with the radiator cap loose. If the coolant level drops below the plate top it up. On your first drive, after ten minutes check the level again to be sure to be sure .
Old 18-06-2006, 08:28 PM   #3
$90esky
and what if i wanted to ditch the thermostat?
is the bleed hole still in the housing?
