Hello All,
can someone give me the steps required to fit the XR50 side skirts? Cheers |
So far I have figured out
1. Remove the plastic clips holding the inner wheel guard on 2. remove the rubber strip along the door sills 3. Slide skirt on to sill 4. line up the front and rear of skirt against the body 5. Secure skirt in wheel well using self tapping screws 6. Replace plastic clips removed at step 1 7. Replace rubber strip removed at step 2 Do you have so secure the underside of the skirt under the car to anything? |
Audi S3
i just sikaflex'd my au2 xr skirts on with the scrivets at the front and a self tapper in the rear wheel arch.
