Old 13-11-2008, 09:37 PM   #31
zksi
Default calibre
Originally Posted by Mr Hardware
Hi the Monty
If i'm not mistaken, Calibre is a Supercheap Auto inhouse brand. Like most things Supercheap makes, its utter crap.
Stick with castrol, and i'd say 10w30's a little light for brisbane weather...
15w40 is a bit safer.
Apparently Calibre is made by Caltex which is good. So far I've tried Penrite, Castrol Magnatec and Mobil, all have the potential for 15.000 kms or more. And Fuchs as well.
you don't have to spend big on synthetics to get good mileage from an oil. I'd stick to either mineral Mobil, Fuchs or Penrite.
zksi is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2008, 09:38 PM   #32
zksi
Default ford oil
Originally Posted by dreadly
Mate use Ford 15w- 40... or 5w-30 I dont know why you'd use anything else?
1 its Ford, 2 its Ford and 3 it kicks ***! Seriously though it really is quality oil ive been using it for yrs now... highly recommend it!
My local dealer says Ford Oil is made by Mobil so you get good quality as well.
Old 13-11-2008, 09:47 PM   #33
zksi
Default 10w30
IMO 10W-30 is too thin for a stock I6, unless its winter in Melbourne or something.
I don't think anyone north of brissie should run anything less than 15W40. We used to run 25W60 in the cabs! 15W40 is the best balance, if you're gonna dip on any side of 15W40 then dip on the 20/25w50 side, boys.
If the manual recommends 10W30 then should be OK in any season providing you use quality (high performance) stuff like Mobil, Fuchs, Motul, etc.
My Hyundai and Mondeo recommend 10W30 for -20 to +40. If the engine is in sound condition then using a heavier oil may cause more damaged than good and compromise fuel economy.
Old 14-11-2008, 10:27 AM   #34
rob_liss_lms10
rob_liss_lms10's Avatar
Originally Posted by BATRB-6
Anyone tryed Royal Purple motor oil it’s available in 0W40, 5W20, 5W30, 5W40, 10W30, 10W40, 15W40, 20W50, SAE 30, SAE 40 and SAE 50 weights.
10W30 or 10W40 would be the choice.
http://www.royalpurple.com.au/html/s01_home/home.asp
I used to use Penrite 10x40, started a slight leak,put in all the additives to stop it including Fuchs (engine honey?)stuff but the leak persisted. Recently I changed to Royal Purple 10x40. The leak has gone, I dont know if the oil had anything to do with that or the additives have finally done the trick. I change oil every 5000k. I also used to use K & N oil filters but have changed to Fram racing. The funny thing about Royal Purple is that the oil really is purple, quite freaky really. Haven't done a oil change yet so cant comment on what it is like after 5000k.
Red bull gives you wings?: nahhh.... we got our wings from TICKFORD
rob_liss_lms10 is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2008, 02:28 AM   #35
zksi
I'd choose AMSOIL over Royal Purple. Or ELF Excellium. These meet the latest specs.
Old 15-11-2008, 09:39 AM   #36
gregsAUII
Me AU's cheap and clean.
gregsAUII's Avatar
Calibre oil did it come in a 6lt bottle or diid you add some other brand??
THE MIGHTY MANLY WARRINGAH SEA EAGLES
Daily - 2013 SR5 Hilux
Toy - 2000 AUII Falcon
Toy - 2010 Kawasaki ZX10-R
Her's - 2017 Camry SX
gregsAUII is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2008, 02:42 PM   #37
The Monty
Just slidin'
The Monty's Avatar
6L has what to do with anything?
MD Mondeo - For the family
NP Pajero - For the adventure
The Monty is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2012, 08:07 AM   #38
glenn454
Default Re: "Calibre" 10W 30 oil
have used royal purple 15/40 full syn
expensive
engines runs quiet
now i use castrol full syn pro edge titanium 10/60
change every 7500km in my TTG
happy with it
quite a bit cheaper
glenn454 is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2012, 10:07 AM   #39
webbiegareth
Default Re: calibre
I was just about to ask that one.... who actually make it. What grade is it? SN? SF?
I've used Penrite 10W50 in the commodore for the past 150,000km's with no issues (it's nearing 300,000km's now) and the Ford AU is currently on Penrite 5W40 but I'm worried about it being too thin so I'll put in 10W50 next time.
Strangely though Penrite have now changed from semi-synth to full-synth for their HPR range.
webbiegareth is offline   Reply With Quote Multi-Quote with this Post
Old 12-04-2012, 11:09 PM   #40
zdenko
2002 XR6 VCT Owner
I've been using Castrol Magnatec 10W40 in the Xr6 since I got it with 130000km's on it. Flushed whatever clean stuff was in it straight away.
33000km's later no issues to report, other than a slight oil leak around the front engine seal. It's so minor though I don't even need to top it up in the 10000km's I service the car in.
However, for quality oil, I use Elf Excellium 10W50 Fully Synthetic in my Mx-5 that sees plenty of track use. I have never had to top up oil in this car using this oil, and it's turbo charged and runs at some rediculous temperatures. Alot of the Mx-5 race guys use it, and it simply just works. Not easy stuff to find on a shelf any where though.
The car had Mobil 1 5W50 in it before, and I found the engine made alot more ratling noises when under stress with this in it. Probably to thin for race use.
SOLD: 2002 AU3 Falcon XR6 VCT on Impco Mixer Gas
Factory Leather and Towbar
Stock 17' rims Perfect After Fixing Myself
Air Hog Air Filter + 2.5 Inch Sterling Mandrel Bent Exhaust + Supercheap Oval Tip.
Carbon Fibre Style Vinyl Wrapped Roof and Boot
zdenko is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2012, 11:56 PM   #41
Day-mow
rexnet
Day-mow's Avatar
going to use ULX 110 as soon as my oil leaks are sorted. probably stick with the 10w30 weight.
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
