Old 28-12-2008, 08:45 PM   #1
RG
Back to Le Frenchy
RG's Avatar
Default Useful AU threads - LOOK HERE BEFORE POSTING A NEW THREAD!!...CONTAINS "HOW TOO"S
Well since this gets updated regularly I'll just make it easier and leave the last post with the links as the current one.
Look below for all your AU need to know's.
Originally Posted by drew`SEVNT5
nah mate, aussie cars are the besterest and funnerest, nothing beats them, specially a poofy wrong wheel drive
RG is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2009, 10:40 AM   #2
InfernoSR
Sales Representative
InfernoSR's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: For research and posted write up on cooling system care and repair in AU.COM and offering help where possible
Not sure where to put this... but its useful info anyway :P
InfernoSR is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2009, 10:45 AM   #4
russellw
russellw's Avatar
I6 Exhaust
Front Hub Replacement
Old 29-06-2009, 09:24 AM   #5
oasisroofer
Is there any type of head unit to replace the original premium soun d in a au fairlane and able to plug in from same loom??
Thanks
oasisroofer is offline   Reply With Quote Multi-Quote with this Post
Old 05-08-2009, 02:38 AM   #6
POELWYK
Lost Boost Gained Class
POELWYK's Avatar
Thanks
U CAN GET A WIREING HARNES FROM ANY CAR PLACE that will fit a AU
2006 BF Fairmont Ghia
2001 AU Falcon
POELWYK is offline   Reply With Quote Multi-Quote with this Post
Old 24-12-2009, 02:38 PM   #7
Jack91
Jack91's Avatar
Surprised this isnt already here:
HOW TO CHANGE FUEL FILTER
http://www.fordforums.com.au/showpos...3&postcount=37
Jack91 is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2010, 12:02 AM   #8
Whoosha
AU DIE HARD
Whoosha's Avatar
Miscellaneous
FUEL ISSUES
FUEL PUMP
Link to the AFF Technical documents, there is a heap of info in here that you WILL find useful,this also includes some how to s
Mods that don't work
Some AU myths and facts
Remove keys form boot with LPGt
HOW TO's from AUfalcon.com.au
HOW TO: Cleaning power window switches
HOW TO: Upgrade your CAI
CAI Install help
HOW TO: Remove shifter surround/replace selector globe
HOW TO: Spoiler removal
HOW TO: Remove / refit side repeaters
HOW TO: Cleaning the Throttle Body
HOW TO: Installing footwell courtesy lights
HOW TO: Changing oil and filter
HOW TO: Painting brakes
HOW TO: ECU reset process
HOW TO: Remove & replace rear brake pads and rotors
Look here for AU V8 mods, tips, tricks and help
AU V8 common questions
AU XR8 Intake pipe mods
AU XR8 coil packs
If it's an I6 you have, look here
How To I6 Water Pump Replacement
How to change your AU I6 Cam
AU I6 HP vs VCT
Brakes & Suspension - If it has anything to do with stopping or making your AU turn, it's here!
Whoosha's Handbrake Adjustment guide
Difference between standard and Premium brakes
Front hub/rotor replacement
AU IRS shock mount replacement
Info on IRS
IRS Hub & Axle Replacement
The complete AU1 to AU111 brake conversion
Swaybars
Interior - If it's inside your AU, check here
How to - changeover interior door handles
How to - replacing door actuators
How to - removing headlining
How to - install console rear courtesy lamps
How to - change gear shifter and surround
GK's "how to" changeover double din stereo head unit
Instrument cluster LED's
Door trim removal guide
Leaking windscreen fix
Height adjustable aerial/centre fascia removal
How to change manual gear lever
Difference between standard and Premium sound
Steering wheel removal/replacement
Water in cabin issues
BA/F interior into an AU
Uncle Ken's seat repairs
Uncle Ken's Grab handle guide
Exterior - If it's on the outside, it's here
Whoosha's guide to painting car parts
AU Rust issues
Painting your headlight surrounds
AU exterior modifications guide
Replace exterior mirror
S1 grill options
Clear side indicators
Here we have some ECU and electrical threads
Speed limiter
Auto trans Power v Econ modes
HOW to replace Plugs, Leads,& Coil Pack
Thanks to;
Peuty
The Monty
au302s3
Whoosha
Superroo
AUbigfoot
RussW
Grand Pa Spec AU
Uncle Ken
for contributing to the list.
Originally Posted by Riksta
Old 10-01-2010, 12:11 AM   #9
Whoosha
AU DIE HARD
Whoosha's Avatar
Just a note for those who wish to contribute to this thread just post your help in the normal part of the Au forum and we can cut and paste the link to this section ,which will avoid havening to sift through pages of How to s to find the rite thread. Keep up the good work gang :lookedat:
Old 08-02-2010, 05:09 PM   #10
blueoval
Critical Thinker
blueoval's Avatar
I found out that Camtech have a new website and now show all their off the shelf grinds for the AU.
http://www.camtechcams.com.au/ford_6cyl_elau.html
"the greatest trick the devil pulled, is convincing the world he doesn't exist"
2022 Mazda CX5 GTSP Turbo
1967 XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
Old 24-02-2010, 02:30 PM   #11
skelly
skelly's Avatar
Default radio code
this is probably a small problem but it annoyed the crap outa me!
if you dont know it simply call your local ford dealership and ask about radio codes, they will transfer your call and they will ask you your VIN number and the name the car is registered and they will tell you.
i know it would have been usefull knowing this instead of reading the whole manual to my car :
skelly is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2010, 10:59 PM   #12
Jack91
Jack91's Avatar
Sure Im not the first to realise but the majority of those links are dead now because aufalcon.com went away. Possible to get them hosted and linked to here?
Old 30-07-2010, 06:27 PM   #13
Whoosha
AU DIE HARD
Whoosha's Avatar
I think I have most back on line from aufalcon.com if I have missed any let me know
Old 15-08-2010, 08:07 PM   #14
atomiclord
I drive way too much...
atomiclord's Avatar
The AU exterior mods link doesn't work.
AUIII Straight LPG
Done: BA XR6T Snorkel, K&N Panel Filter, EL Belt Cover, 2.5" Exhaust
To Come: Extractors, Tran. Cooler, Lowering, High-flow Cat
atomiclord is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2010, 09:42 PM   #15
Whoosha
AU DIE HARD
Whoosha's Avatar
Does now thanks
Old 06-03-2011, 09:07 AM   #16
Whoosha
AU DIE HARD
Whoosha's Avatar
Just added a few more threads keep up the good work gang and let us Know if there is any we have missed
Old 19-03-2011, 08:44 PM   #17
atomiclord
atomiclord's Avatar
Default Re: Useful AU threads - LOOK HERE BEFORE POSTING A NEW THREAD!!
The throttle body cleaning pics are down, is there an alternative thread that shows how to clean it?
EDIT: I knew there was one somewhere. GK's tute: http://www.fordforums.com.au/showpos...2&postcount=48
AUIII Straight LPG
Old 01-04-2011, 10:29 AM   #18
Whoosha
AU DIE HARD
Whoosha's Avatar
Miscellaneous
FUEL ISSUES
FUEL PUMP
CAI Install help
AU XR8 coil packs
AU I6 HP vs VCT
Info on IRS
Swaybars
Bushbasher's Climate Control Fix / Offer
AU Rust issues
S1 grill options
Speed limiter
Thanks to;
Peuty
The Monty
au302s3
Whoosha
Superroo
AUbigfoot
RussW
Grand Pa Spec AU
Uncle Ken
AU11Pursuit
Old 02-06-2011, 05:13 PM   #19
au11futura
ROCKING THE EL FUTURA
au11futura's Avatar
guys i had a prob with determening what king springs suit my car and another forum member kristo gave me this link, so im posting it up as a guide for people with the same question.
http://www.kingsprings.com.au/catalo..._catalogue.pdf
BA MK11 XR8 ENFORCER NOW SADLY GONE
My build that was http://www.fordforums.com.au/showthread.php?t=11267696
ENVI BA XR6T
BUILD THREAD..http://www.fordforums.com.au/showthread.php?t=11345961 TAKEN BY THE EX
NOW A EL FUTURA
EB MONTY NOW IN THE SHED
BACK IN THE E-SERIES
THREAD DIGGEr
au11futura is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2012, 09:05 PM   #20
Bucknaked
Bucknaked's Avatar
Any Info available on how to remove the cluster?
FG2 XR6T
KIA Cerato
2022 Kawasaki Z900
Bucknaked is offline   Reply With Quote Multi-Quote with this Post
Old 26-04-2012, 09:29 PM   #21
b2tf
not here much anymore
b2tf's Avatar
Use a small screwdriver to remove the 2 black plastic caps at the top of the fascia, behind them are philips head screws - remove
Pull out the blanking plate where the fuel/boot release buttons normally are (ute has a blank plate cos it doesnt have them obviously)
Use a long screwdriver or similar to get behind the cluster and gently prise it out from the dash, check that the clear plastic fascia does not get caught on the dash, if it does just wiggle it out
The cluster should come out enough for you to reach the 2 wiring looms that go into the back of it. They are different sizes so you wont stuff them up when you put them back in.
Cluster should now come out as a whole unit. To pull it apart (i.e. to change the background etc) use a small flat blade screwdriver to take the front plate off the back of the unit (easier to understand when you're looking at it). Be careful because the clips can be fragile and break easy. If you do take it all apart Id recommend putting some electrical tape all around it when you put it back together to keep dust etc from getting inside it.
RAM 1500
Old 05-05-2012, 04:41 PM   #22
Bucknaked
Bucknaked's Avatar
Thanks Austin for this information. I will give it a go and see how I go. Thanks again.
FG2 XR6T
KIA Cerato
2022 Kawasaki Z900
Old 02-11-2012, 06:36 PM   #23
GCPursuitPower
AUII XR8
GCPursuitPower's Avatar
Is there a wiring diagram for the AU, as I bought a push button starter kit and I need to know how to install it into my car via the ignition barrel and the 12v power system.
Ford XR8 AUII Sedan, 5.6L Stroker Engine 250kw.
GCPursuitPower is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2012, 08:59 PM   #24
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Check here:
http://www.fordforums.com.au/vbporta...rticle&id=1307
And here:
http://www.fordforums.com.au/vbporta...article&id=788
Rayban76 has also installed the GT push button starter, so if you have any queries, send him a pm.
Stu
2002 AU II LTD
2002 XR8 pursuit 250
auIILTD is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2014, 03:05 PM   #25
v8der
Naturally Aspirated
v8der's Avatar
Default Re: Useful AU threads - LOOK HERE BEFORE POSTING A NEW THREAD!!...CONTAINS "HOW TOO"S
Hi guys
Wondering if it's just a straight swap AU Fairmont leather seats into an AU3 XR8 sedan?
cheers
2016 Ranger WILDTRAK PXII 6sp manual Pride Orange
1993 EBII Fairmont 4sp auto Biscayne Blue
Previous Forms of Transportation:
1978 302 V8 XC | 1982 4.1L XD | 1994 ED Fairmont | 2000 AUII XR6 | 2002 AUIII XR8 | 2003 BA XR6 } 2011 SZ Titanium Territory | 2006 BF Pursuit BOSS 290 6spd manual #57 | 2003 BA Fairmont 5.4L 4spd auto |
v8der is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2014, 06:50 PM   #26
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
I think so, if the seats are powered you would have to power them up. Not sure the the wires are already there. Bolt wise they are the same\
UK
Old 01-09-2014, 12:29 PM   #27
v8der
Naturally Aspirated
v8der's Avatar
Cheers UK
I actually did this back in March. Got a seat of Millenium Leather seats from a Fairmont AU. The cable loom for the power seats was there already so it was just plug n play. Had some minor issue with the rear seat brackets being a different size to the XR. I had my local trimmer just swap the foam over.
Old 05-12-2015, 02:54 PM   #28
MNM96
LIFELONG DJR SUPPORTER
MNM96's Avatar
Is there a "How To" for replacing a Harmonic Balancer at all?
MNM96 is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2015, 06:37 AM   #29
MNM96
MNM96's Avatar
Bump.
Old 10-12-2015, 07:32 AM   #30
Evgeni
Auto Nerd
Evgeni's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: In recognition of the many hours spent scanning information for the benefit of AFF members.
You will need a puller that grabs the balancer from the inner frame so to speak. GG technics make one but they are pricey.
If you have an air gun you can take out the crank bolt easily, but usually most guns wont fit unless you take out the radiator. By the way, electro fans and accessories belt needs to be out. I am assuming that there are how to's elsewhere for these, but sing out if you need help.
I find it quicker by hand.
Underneath the inspection plate for the torque converter is a hole where you can access the ring gear. You can jam this up with a large screwdriver with one hand and using a breaker bar, you can crack the bolt. 22mm bolt.
When pulling the balancer out, it will slide over the bolt, but not the washer. Take the washer out and put the bolt back in for the puller to press up against and you can get the balancer out.
Change your crank seal if it is leaking.
Silicone on the keyway of the crank, fit the new balancer and use the bolt and washer to press back in. 125nm is the torque spec and yes you will need to jam up the ring gear when torqueing the balancer bolt.
Evgeni is offline   Reply With Quote Multi-Quote with this Post
