Go Back   Australian Ford Forums > Club and Speciality Forums > Ford Car Clubs > All Ford Club of Western Australia
Old 29-04-2020, 03:05 PM   #1
Powers351
Default ED Falcon 5.0 EFI to Carb Manifold
Probably been asked a thousand times before, want to know if anyone has an E Series with a carb manifold on their 5.0? Curious to the room between the manifold to*bonnet, any fitting/clearance*issues? Running roller cam block, engine out at the moment for rebuild, any pics or info much appreciated, I know the whole EFI/Carb debate is a topic in its self, I’m going with FiTech Injection on this one, had awesome results in the past just never used*in*a ED before, Cheers in advance
Powers351 is offline   Reply With Quote Multi-Quote with this Post
Old 30-04-2020, 12:58 PM   #2
Franco Cozzo
Franco Cozzo's Avatar
Default Re: ED Falcon 5.0 EFI to Carb Manifold
I'm not sure why you would bother going from multipoint injection to throttle body injection as it's a step backwards.
Old 30-04-2020, 01:10 PM   #3
Bossxr8
Peter Car
Bossxr8's Avatar
Especially when the factory ecu can be tuned with a moates quarterhorse.
Old 03-05-2020, 12:33 PM   #4
Powers351
Yep well aware of all the nitty gritty stuff, looking to do something different, was basically looking for images on others who have done the same.
Old 03-05-2020, 12:36 PM   #5
Powers351
Basically because I want to try something different, I have used this system on previous engines with great results, just looking for images of others who have done it, looks like I will have the job completed before I get any, these forums don’t seem to move too quickly, of the ones I am in anyway.
Old 12-06-2020, 03:05 PM   #6
Powers351
Well it’s all up and running with rebuilt engine and FiTech installed, can honestly say it’s awesome to drive, haters will hate I’m sure but I personally like it, can tune in my driveway or on the fly without a Dyno or a laptop in sight
Old 15-06-2020, 06:45 PM   #7
stavros68
Looks great ,doing something similar, xe Wagon with a Windsor 347 with fitech .
Good to see something different and with old school look , what’s controlling the auto ? If it’s auto .
stavros68 is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2020, 06:47 PM   #8
Powers351
Nah swapped it Over to manual mate, I believe there is a TPS breakout harness available for trans input tho
Old 15-06-2020, 06:54 PM   #9
stavros68
Putting a btr behind mine , did you run standard fuel pump or upgrade ?
Old 18-06-2020, 02:34 PM   #10
Powers351
Replaced the pump with new one but the FiTech only runs a 58psi fuel system, replaced the return hose to 3/8” and all works perfectly
Old 18-06-2020, 02:36 PM   #11
Powers351
Yeah understand all of the, tho I wanted something different and I can tune/adjust any and all settings with the hand held controller whenever I like, all seems to work very well
Old 21-06-2020, 11:47 PM   #12
Sprintey
Sprintey's Avatar
Looks great Powers351. Any pics under the air cleaner, do you have an old school carb under that? I put up a thread in the pub similar, going back to old tech that is able to be tuned by hand.
Nice work at any rate.
I6 + AWD
Sprintey is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2020, 11:53 PM   #13
Powers351
Cheers, it’s actually FiTech EFI (throttle body EFI) looks like a carb but has 4x injectors, self tuning/learning with very minimal initial input settings
Old 22-06-2020, 12:46 AM   #14
MrEL
Sick Puppy
MrEL's Avatar
What's the setup worth?
MrEL is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2020, 12:49 AM   #15
Powers351
Hi MrEL, depends where you buy and which size unit you get, 400, 600, 800 or 1200hp units, mine is a 600hp unit and I paid $1400 for it, fits any square bore intake manifold, good instructions, easy set up and comes with all bits needed, sensors and stuff
Old 22-06-2020, 12:53 AM   #16
MrEL
Sick Puppy
MrEL's Avatar
That's actually really fair pricing.
Where did you get it from?
Old 22-06-2020, 12:56 AM   #17
Powers351
Sent you a PM mate
Old 30-06-2020, 04:08 PM   #18
Sprintey
Sprintey's Avatar
Thanks for the pic & explanation, Powers351!
I6 + AWD
