Fantastic Plastic
G'day everyone , i was thinking of putting some small oval shaped extra driving lights on my car ( mount them in the pods in the front bar/spoiler ), i wouldn't mind a bit more light when driving of a night , especially pointing onto the actual road a bit more .. problem is , im 50/50 on weather i would like the look of them on the AUII XR though , has anyone got any pics of the AUII XR with the small driving lights in the pods ? .. cheers ..
#2 | |||
Small driving lights mounted that low wouldnt do a whole lot would they? Thought it would be more for looks down there, much like mine. |
_Oo===oO_
I wouldn't do it to mine, the high beams pretty much turn night into day as it is on the XR's.
Before going ahead I'd recommend getting your headlights adjusted correctly first.
Resident Nyctophobic!!
no daylight is when your ute looks like mechaniks lol
Fantastic Plastic
Well i popped down to k-mart, scored it lucky , i got the last box of the small oval Monza H3 55w driving lights, was marked to clear too because the plastic wrapping was missing and a bit of the box damaged lightlly , but open checked it all out and everything is ok and all the parts there , the wiring /fuse/relay etc etc ... got it for $20 ! , i couldn't refuse for that much. I just installed them about 10 mins ago and i must say they look nice
Was V6corp
Of course when ya do, take some pics
Sounds like the same ones that redxr8bloke got for his xr8. About the only thing that is out there that will suit the size / cut out of the pods.
Fantastic Plastic
Here's some crappy pics , excuse the quality as my camera is crap , i need a new 1 , give you an idea though , allthough the pics don't do the full justice , the tadd reflection almost makes the 1 light look a little crooked , allthough it isn't ;) .
Oh - you can also sorta see how that turtlewax color cure with the chipstick worked too in these pics..
Fantastic Plastic
Well ? , what's everyones opinions ? , like them or not ? , i think i like them ! ..lol , they are growing on me since installing them , they fitted perfecty into the pods
Yep.. looks good. they line up perfectly with your high beams.
#11 | |||
#12 | |||
Fantastic Plastic
lazy ! - yeah you got that right ! ..lmao - but i have fitted them - i just haven't wired them yet , i don't wanna stick a hole in my dash for the extra switch or use the crappy extra switch they supply , i'm just gonna wire them up in conjunction with the standard driving/parker lights so they come on with the normal driving lights switch .
#13 | |||
#14 | |||
Fantastic Plastic
#15 | ||
Fantastic Plastic
By the way , it only took like 10 minutes to mount them/the brackets & lights ... which wasn't too too much time - i managed to put down my can of bourbon & coke until i was finished !
#16 | ||
Are the pair that you bought fitted with a small parker light as well as the H3 globe?
#17 | |||
Fantastic Plastic
The 1's i got are ... Monza 1200 die cast/rust proof driving light kit , it states 'with extra projector globe' , includes easy to fit wiring kit , H3 12v 55w , small oval shape.
#18 | ||
Formally Kia Chaser
They looks good. How about chucking in a really bright light in the indicator asembly (on the AU XR front bar) so you get a really wide beam... for like roos and stuff!
Kia Grand Carnival (2006) Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw HSV Clubsport R8 VY (2003) Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
#19 | |||
Fantastic Plastic
![]() As far as that comment about a really bright light in the indicators , i nearlly laughed at first , then i though about what you said and if i am understanding you correctly i think you meant like mount an Extra globe inside the indicator so u have like a side beam to ligh up the side of the road ? - good idea in theory - especially for those who have roo's in their area ! ( not me ! ..lol ) , but i 'think' that a extra white globe inside the indicator lense wouldn't do much prolly except melt the lense ( i think the indicators are 22w if i remember corectlly ) thus the housing for the indicatour would probably only withstand aound that wattage before heat became a problem , + the inside reflector and the lense on the indicator isn't realy designed for a beam to be projected out of it , they are a frosted lense , unlike a clear driving lense . good idea though ..
#20 | ||
When I do eventually get around to fitting mine, I will be mounting them behind the nose cone to keep in line the way the h/lights & d/lights are mounted. The only downside to this is that I will have to drop the nose cone to do this.
#21 | ||
Fantastic Plastic
Well i got around to wiring them up , i have an extra switch hidden in the fuse compartment in the cabin incase if i want to switch them off while i have my parkers or headlights on ( unlikelly though , is why i hid the switch away - didnt want to go ruining the dash to mount a cheap lookin switch ! ) - so as it is the switch in the fuse compartment remains on , and then i just use the normal parker/headlight switch to turn them on and off autimatically with my other lights .
Just went out and drenched myself in the rain to get a few pics for you all with them turned on . I like them , allthough i wouldnt mind changing the globes to whiter globes at a later stage , they look a bit yellow compared to the headlights in the pics , allthough the camera did exagerate it , they look pretty much the same color as the headlights in person ... heres some pics anyway .
#22 | ||
My 1st set of Wings!!!
Mate that looks awesome. I was thinking about doing this myself, but the legalities over here made my head spin so never went with it...wish I had of now grrrrrrrr might have to do somemore homework on this lol
PROUD OWNER NAROOMA BLUE 2002 AUIII XR6 :sm_headba |
#23 | |||
Fantastic Plastic
Thanks mate , nice comments appreciated ;), they have defianatelly grown on me , got to test them out tonight - awesome ! - I dunno where your living and the legalities of them , but they are actually diving lights , not spot lights or fog lights , they are only 55w , states that do usually ban you from hooking them up to the parking lights & headlights still allow to to hook them up but run them off jsut an independant switch ;) - being driving lights , they arent no brighter than normal headlights so it makes me wonder why they would be illegal where you are .
#24 | ||
Fantastic Plastic
pics ...., lights on , in the rain ...
#25 | ||
Formally Kia Chaser
#26 | |||
Fantastic Plastic
As requested ... you all know the go with my cheap webcam camera by now ! ..lol , so don't expect brilliant pics or quality ;) .
#27 | ||
Barra Turbo > V8
they have 2 globes in them what kinda lights are they make and type
-2011 XR6 Turbo Ute - Lux Pack - M6 -2022 Hyundai Tucson Highlander Diesel N Line |
#28 | ||
Barra Turbo > V8
damn i just seen it sorry
#29 | ||
Fantastic Plastic
Well i got to test them out lastnight , went into the casino in the city to get blind ( i got the missus to drive ! ;) ) , and oh my i must say they are great , turns night into day , much easier to see potholes etc in the road too of a night , so it looks like they stay - besides the look of them has grown on me , imo i really think they suit the front of the AUII now i have them on there ..lol
#30 | |||
