Old 02-09-2018, 12:06 PM   #1
280
Default 1994 kh laser timing belt crank bolt
Hi all. I am currently changing the timing belt on my KH laser 1994 1.8 efi engine.
I have looked everywhere but I cannot find which way to turn the crankshaft bolt(the one near the harmonic balancer)to undo it.
On this engine it needs to be undone to remove a plate to allow the timing belt to slip off the bottom pulley. The bolt is not listed as a spare at any auto shop I've called, so I cant get a look at one.
Any knowledge / help greatly appreciated.
Thanks 280
280 is offline   Reply With Quote Multi-Quote with this Post
Old 02-09-2018, 12:18 PM   #2
foxtrot3
foxtrot3's Avatar
Default Re: 1994 kh laser timing belt crank bolt
Hi. In over 40 years in the auto trade I have never seen a crank bolt that isn't a normal r/h thread. That being said I can't for the life of me remember if we had to pull the crank bolt on my sons mazda when we did the water pump. Cheers MD
PS Just remembered, we didn't change the belt as it still looked new from the engine rebuild from the prior owner but We had the pulley off when we did the AC fitting and it was a normal bolt. Cheers MD
HI
I'M MICHAEL
Old 02-09-2018, 12:28 PM   #3
falconhell74
falconhell74's Avatar
It's R/H thread the easiest way is to use a beaker bar , rest it against the chassis and crank the engine - don't start it though just "bump" it to crack it.
XC GS OLD SCHOOL MUSCLE
Audi A4 S-line quttro
Xc falcon
Previous fords-
xc falcon 500 ,250 x flow 3 speed
xc gs worked 250 x flow 4 speed
xa Fairmont 302 auto wagon
xb falcon 250 log auto 4 door
xb falcon 200 log auto ute
xc gs project - had to sell :-(
xc gs 302 4 speed 4 door
xc gs 351 auto 4 door
zf fairlane 302 auto
zk fairlane 250 x flow carb auto
zl fairlane 250 x flow EFI auto
xg ute , BA falcon dedicated gas
xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5
falconhell74 is offline   Reply With Quote Multi-Quote with this Post
Old 02-09-2018, 01:18 PM   #4
280
Hi everyone.
Thanks for the quick responses. I have just organised a breaker bar. I will go with the right hand thread. Foxtrot3 thanks for that info about typically r/h threads. Good to know.
I will post when its off.
Thanks again everyone.
Old 02-09-2018, 05:51 PM   #5
280
Hi
I used the starter motor method. It worked with a three foot breaker bar and the smallest amount of crank I could give it.
Thanks
Old 02-09-2018, 07:03 PM   #6
falconhell74
No worries mate just make sure you line up the timing marks before you remove the belt
Xc falcon
Previous fords-
Old 02-09-2018, 09:16 PM   #7
280
Hi
It has all gone well and is back together, but one small
potential problem.
The lower timing belt pulley is located onto the crankshaft with a 6mm square key about 25 mm long.
This key is very snug but is able to move backwards and forwards in the crankshaft / pulley slot about 5 or 6mm. When it does move forward there is only about 10 or 12mm locking the bottom timing belt pulley to the crank. ie 10 or 12mm driving the camshaft.
Is this normal? Someone has changed the belt previously and may have fitted a shorter key. Should I be concerned, or is it normal to have this small amount of key driving the cam?
Thanks
