Old 22-04-2021, 11:18 PM   #1
gencer
Default Ford au , te50 v8 coolant issue help please
Hi guys,
I have a te50 which Was handed down to me from family and I’m trying to diagnose the coolant boil issue.
After 10-15mins idle the coolant bottle will started to boil crazy.
What I’ve looked out for,
Seems like it’s got a new water pump (someone tried to fix it before)
I put a new thermostat and also tried with no thermostat
No oil mix (in water or oil)
When on idle at the start doesn’t seem to have air in the coolant system
And one have any ideas before I start taking the motor out for major head damage?
Thank you guys in advanced.
gencer is offline   Reply With Quote Multi-Quote with this Post
Old 22-04-2021, 11:43 PM   #2
Default Re: Ford au , te50 v8 coolant issue help please
Have you checked the recovery reservoir cap is holding pressure? See https://rxmechanic.com/symptoms-of-a-bad-radiator-cap/ and https://www.holtsauto.com/prestone/n...lant-bubbling/ etc
Cooling System Pressure Cap
To maintain pressure, cooling systems rely on a pressurised cap that keeps the system at a constant pressure while allowing coolant/antifreeze to flow to the expansion reservoir. If the cap develops a fault or is replaced with one that’s not compatible with the system, air can get into the system and cause problems.
Symptoms:
Bubbling in the coolant/antifreeze reservoir
Bubbles around the cap seal
Overheating
Also check the spring in the lower radiator hose has broken or partially rusted away so the hose is collapsing; hold the outside of the hose from below while someone pulse revs the engine.
Old 23-04-2021, 08:10 AM   #3
FroudeyBrand
Originally Posted by gencer View Post
Hi guys,
Is there water laying on the side of the head mainly the drivers side head cover / tappet cover ? if so I would be $50 that the rear hose that goes behnind the back of the motor to full of **** from under 20 years of **** its like a 800 dollar fix at a decent mechanic
FroudeyBrand is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2021, 01:25 PM   #4
Bosko
Use a TK Tester? I think you will find it’s got exhaust gases in the cooling system. Which says head gasket problem.
Current
Project XE (Track Car) 302 Cleveland and C4 Auto currently.
Previous
1973 XB GT Coupe 351 4V, 4spd Top Loader and 9" Diff
Bosko is offline   Reply With Quote Multi-Quote with this Post
Old 02-05-2021, 07:58 PM   #5
undertow
Technical Contributor: For members who share their technical expertise. - Issue reason: AU Aux input HOW TO.
Radiator fans working?
If the water pump's turning, thermostat opening and fans running it should not boil at idle...
undertow is offline   Reply With Quote Multi-Quote with this Post
