Old 05-02-2006, 12:40 PM   #1
!Gn|T|0n
!Gn|T|0n's Avatar
Default Rotor machining in Brisbane.
Good morning all.
I’m after recommendations regarding places around Brisbane (preferably inner south where I work or inner north where I live) where I can get my DBA cross drilled and slotted rotors competently machined. Has anyone had any good experiences anywhere? I have quite a pronounced brake shudder, which I feel mostly in the wheel.
How much should I expect to pay?
Thanks.
Still saluting the Ford flag.
!Gn|T|0n is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2006, 05:25 PM   #2
Lightning Strike GT
Lightning Strike GT's Avatar
There is a place on Rode Rd in Chermside opposite the Prince Charles Hospital I can not remember the name of the place
Regards Alan
FG GT in Lightning Strike
5th anniversary edition in manual 1 of 25
And an 2019 MD Mondeo Trend Wagon in Platinum White
Lightning Strike GT is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2006, 05:33 PM   #3
tufLTD
tufLTD
tufLTD's Avatar
Be careful when getting slotted rotors machined. Most brake lathes won't cut them properly, the cutting bits jump on the slots. Getting them surface ground is a better way to go, like they do with flywheels.
tufLTD is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2006, 07:12 PM   #4
Biggoggs
Rider on the storm
Wow, you managed to warp cross-drilled and slotted rotors?
Maybe you should get one of those Brembos with half a dozen pistons
Biggoggs is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2006, 07:24 PM   #5
!Gn|T|0n
!Gn|T|0n's Avatar
I've read conflicting opinions on the effectiveness of machining slotted rotors. tufLTD, would you explain to me the difference between machining and surface grinding? Does the former use a wheel / flat disc and the latter a blade? Essentially, they're no good the way they are. I do not drive the car hard. It either lives in the garage or does stop start driving to and from work for the majority of the time. I avoid driving through puddles when the rotors are warm, wait for them to cool before hosing them when washing the car... basically I treat them much better than the average person I'd wager and still they've done me wrong after.
Old 06-02-2006, 09:28 AM   #6
tufLTD
tufLTD
tufLTD's Avatar
Machining uses a lathe with 2 cutting bits, one for each side of the rotor.
Surface grinding uses a flat rotating grinding wheel. The rotor is mounted on a flat bed. This method seems to produce a better finish on cross-drilled rotors.
Warped cross-drilled rotors isn't uncommon. My boss has warped his front & back rotors on his Commodore & we've had a few customers with the same problem.
