Old 12-11-2020, 10:42 AM   #1
TristanAvery
Default 2006 Ford Focus Door Lock Actuator Rivet
Just curious what the sizing of the rivet is in the door lock actuator?
And where to get such a rivet in South Australia or just Australia in general.
TristanAvery is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2020, 12:08 AM   #2
GTLEGEND
Default Re: 2006 Ford Focus Door Lock Actuator Rivet
Here are all the parts of the front door locking system of a LS LT Focus. I don't see what rivet(s) you are referring to? Can you identify what you need.
Old 13-11-2020, 05:27 PM   #3
TristanAvery
On the actuator that keeps it locked in. Cause the parts that attach it to the metal skin (the bit that has the speaker and the electric window motor, under the door panle) are broken on the one I bought, but the one in the car is still good. So just need to switch out the actual actuator, which is just a plastic clip and drill out the rivet, than re-rivet it.
Cause supposedly its the "Ford N808594-S100", but can only find them from America and in 25 packs and shipping cost like $40
Edit: its also the LHR door lock if that makes any difference, and doesnt have the stick bit (22134B)
Old 13-11-2020, 05:47 PM   #4
GTLEGEND
Here are the rear door lock components:
As for part number N808594-S100, that was used here in the 2000-2002 Tickford Converted Mustang that held the handbrake bracket to the floor. Obsolete from Ford, I believe its a 6.4 blind rivet. So go to any fastener place and they should be able to help as per example below.
https://www.ebay.com.au/itm/Qty-25-D...UAAOSwkXdd8wgo
Old 13-11-2020, 07:56 PM   #5
TristanAvery
Cheers for all the help.
Old 02-03-2021, 11:53 AM   #6
TristanAvery
An update (bit late).
The ones I bought of ebay, way too big.
Cant remember the size i ended up using, but came with the rivet gun as a set (you know the ones where you get a bunch of sizes) just had to drill the hole a teeny bit larger.
Door now locks with the rest of them
