Old 06-05-2021, 03:42 PM   #1
FroudeyBrand
Default Stupid Question FG Upper intake of AU?
So what are the chances of an FG upper intake / snorkel / tube assembly how ever you say it..
The inlet from ontop of rad support to airbox.
Will it fit onto the AU airbox?
FroudeyBrand is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2021, 09:24 AM   #2
asimplelife
mechanical novice hopeful
Default Re: Stupid Question FG Upper intake of AU?
I haven't done any of this myself, so I don't know.
But I am sure I have read about it previously here on this forum;
"What may work better for these is getting a B-series airbox ... they fit from my understanding ... and the F6 lower snorkel .... which will pull clean/cold air from around your headlights in an AU XR. You'd get more benefit from this than the over-rad snorkel."
Maybe try searching amongst these;
https://fordforums.com.au/showthread.php?t=97039
https://www.google.com.au/search?q=fordforums+What+may+work+better+for+these +is+getting+a+B-series+airbox+site:fordforums.com.au&sxsrf=ALeKk00 oY6kBjDtPo8JMZeX4bUZeiCE-hg:1620512505438&sa=X&ved=2ahUKEwiskvbBj7vwAhXOzjg GHfk_Bm4QrQIoBHoECAYQBQ&biw=1920&bih=938
asimplelife is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2021, 09:34 AM   #3
mad2
Regular...with metamusal
welll i know the AU will fit the BA/BF as i'm using one ..... so . . i think the airbox side will fit on, not sure of the rad support side tho. i do know where there's some AU's/FG's that i could try it on ....... earliest would be wednesday arvo tho before i could test fit.
Old 10-05-2021, 10:09 AM   #4
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
I did this...
Originally Posted by Uncle_Ken View Post
Whilst the front was off I did this...and extra (be it small) air intake
1. get an old plastic pipe connector, make hole to fit
2, Connect...inside
3, only hard part as the pipe blocks the screw
UK
It was cheap and simple. You could use a larger diameter connector if you wanted to.
