06-02-2009, 05:01 PM | #1 | ||
I just did a compression test on the car. I kept the engine cranking until the highest value was reached. Here are the results:
Cylinder 3 has a noticeably lower PSI value as well as taking more rev/crank to reach it. Cylinder 2 has a closer PSI value to the others but takes slightly more rev/crank to reach it. Are the measured values correct? I will do a wet test on cylinders 2 and 3. What type of oil should I use in the test (anything specific)? Is there anything else can do to see what is wrong with the cylinders? NB The test was done as part of the hunt for the cause of my rough idle. |
06-02-2009, 05:58 PM | #2 | ||
RIP...
That all looks fine, though you don't really need to crank more than 4-5 times.
. Oval Everywhere... |
06-02-2009, 08:36 PM | #3 | ||
I found it hard to get consistant readings by doing it 4-5 times, so I just did it until the max compression was reached. It still seems a little strange that the values of 2 and 3 differ. I'll do a wet test tomorrow and see what happens.
06-02-2009, 08:56 PM | #4 | ||
SKID IT
before i done the head on my turboed au the commpression was all over the shop and it ran fine, it differed from 150 down to 130 but 2 was the highest (compression is low becasue of the decompressed head)
Style, Create Your Own
BF XR6T Ute - 422rwhp tuned by FPT Toowoomba Where the boost junkies hang out -Forced Ford Forums |
06-02-2009, 09:01 PM | #5 | ||
within 15 lb`s is the tolerance i was told.
07-02-2009, 12:11 AM | #6 | ||
as long as it aint burnin oil its all good
au2 s i6 5 spd , au series 1 xr6 hp motor, cam advanced 5*,jmm cai ,topgun leads,pacey 4480's,3 inch cat,lukey 2 1/2 sports zorst and 3.89 lsd,standard ecu. current best,14.939 @ 93.17. |
07-02-2009, 07:15 AM | #7 | ||||
RIP...
When one cylinder is 50psi down you'll have something to worry about. A wet test is only done to determine wether it's the rings or valves which are stuffed. I wouldn't bother as your readings clearly show that nothing is stuffed.
07-02-2009, 09:10 AM | #8 | ||
Ok then. Thanks for explaining it to me. Saved me the hassle of doing something that was unnecessary
07-02-2009, 05:47 PM | #9 | ||
justa6
yeah seem's ok, as long as there is not 1 low as. but should only crank it a couple of times.
09-02-2009, 07:48 AM | #10 | ||
With da Warlords
Just a bit of info for future reference. The way the test is usually analysed is by a percentage. As long as all cylinders are within 10% of eachother, thats is considered perfectly healthy. In this case, obviously theres nothing wrong with it.
Food for thought :-)
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear. For Sale: Parachute. Only used once, never opened, small stain. Windsor Warlords AU III XR-8220 300+ rwhp of Manual fun XR50T Ute - 300rwkw (give or take depending on the day)
