08-10-2007, 05:21 PM | #1 | |||
ive been 4490'd
hey all my rear transmission seal in my au2 forte is stuffed and ive been qouted 130 to replace by a mechanic.
Is this a good price? or do ford do better, cause i know ford dont usualy do better prices. hwere is the best place to usually go to get it done? cheers
08-10-2007, 05:30 PM | #2 | ||
Its Resonating!
I would go to a trans specialist, that sounds about what I got mine done for.
08-10-2007, 05:32 PM | #3 | |||
ive been 4490'd
sweet thanks for the info, ill most probs go to a trans specialist then, as long as others are getting it for 130 thats good then too.
cheers
08-10-2007, 10:40 PM | #4 | ||
Mate be sure to check the rear bush,they are usually worn hence causing the seal to leak.
08-10-2007, 10:42 PM | #5 | ||
they are pretty easy to do around 1/2 hr labour plus the seal is all id pay...make sure they use a genuine ford seal they are better (have a tripple edge rubber on them) also check that the extension housing gasket isnt leaking as well.....with a seal gasket and bush youd be lookn at around 1 to 2 hrs labour no more and parts
