Right out sideways
Hey guys, a litte help would be appreciated, emailed the company 4 days ago, no response.
I got a TP Link (TG3269) PCI network card, as i want to set up a gigabit network between my comps to get quicker transfer rates. I install the card, and install the drivers and at the end of the setup i get this error ![]() I got the latest drivers from TPLINKS homepage, same thing. Would this error be coming up because i am using the network card built in to the m/b ? sys config is : P4 3.2ghz, shuttle m/b, win xp sp2 any help would be great
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302 |
#2 | |||
Dual O2 sensors
Have you tried disabling the onboard lan?
Black 1990 300zx Twin Turbo 5 Speed Manual ![]() Blue 2004 Mini Cooper S 6 Speed Manual - Yes, thank you Amanda. I realise now that you updated my signature to include your car. ![]() |
Possible conflict.
Try disabling the ol network connection and try again. Unless you downloaded the worng driver, if thats the case use the driver that came with it. |
Were you logged into the administrator account when you installed it?
What other pci cards are installed Whats the mobo model Try this: Get into device manager (start>run>devmgmt.msc) View>Show hidden devices There could be a driver in there that trying to use the same resources that your network cards trying to use. If not it may lay with interupt requests (IRQ) or Bios needs an update. Last edited by BlackLS; 01-02-2006 at 06:58 PM. |
Formerly au^ute
Start by disabling/removing other network devices on the system.
Right out sideways
M/B isnt shuttle, its a Gigabyte GA-8iP775-G.
Other PCI cards are, Audigy 2 sound card, HDTV Card, Firewire card. I disabled the motherboards network, and restarted and it still wont start the other card. EDIT: Should i remove the drivers for the m/b network ? Re-installed it with the drivers that came with it. its wierd the XP drivers on the disk are only 200kb unzipped, off the website the XP drivers are 500kb. did the device manager as you said, heres what comes up: ![]()
Right out sideways
Just pulled the card out, and installed it in the other computer, and it installed no problem. It has a m/b network too which is active. so i guess its conflicting with something on my main pc. wierd.
I am guessing i can use a crossover cable to hook the 2 computers up, and then with the other network adapter on my 2nd pc, i can hook that up to my adsl router ? if that makes sense ?
Do you have 2 Gigabit cards installed on your machine? From what I can see you have TP-Link and Marvel Yukon
Is the Card you are trying to install Marvel Yukon? or TP-Link? From what I can see just there, you will have one card conflicting with the other. If this is not the case and you only have 1 Gigabit Card. Uninstall BOTH those Gigabit Cards (one is obviously wrong). Restart the computer. Do not install any drivers. Let Windows XP decide which drivers to use. Then your card should be working fine. If you need to update the drivers. Go to the same screen as you have above, double click on the Network Card and click on Drivers. Click Update Driver and click Do not search I will choose from a list Then Click Have Disk Browse to the unzipped contents of your newly downloaded updated drivers and look for a blahblahblah.INF file. Double click on this and let the machine do the rest ![]() Hope this helps |
And as for the setup, I drew a nice picture for you!
Senior 3FB Navigator
Why not just buy a 5port Ethernet Switch?? They're cheap enough and that way you don't have to share the Internet Connection from the Box connected to the ADSL modem. Just plug the modem into the switch and then both PC's into it. You can probably even get a half decent ADSL modem with 4-5 Ethernet ports on it as well for under $80 if you look around!
You should be able to have more than one network card on your pc working at once. Onboard or not. I have two working right now with no problems. Check to see that the settings are correct for your onboard card in the System Properties/Device Manager screen. Perhaps you need to download the latest Motherboard drivers? Even swapping the order of the PCI cards can have different effects! |
Right out sideways
my adsl router is a 4 port wireless 108mbit one, but i want to connect the 2 pc's directly to have gigabit connection, alot quicker for storing large files, and then just share the internet.
thanks for the diagram clontarf , thats what i am wanting to do.
