27-02-2014, 11:22 PM | #31 | ||
CNC fixer guy
Weekend Toy: S1 AU Fairlane V8 with LTD bits, Tickford 17" wheels, front and rear chin spoilers, series 2 front brake conversion with Super pro bushes, Pacemaker headers, rear muffler removed, Kings/Pedders lowered suspension, Koni adj rears, painted headlight bezels, HR 2300kg hitch, 2 stage shift kit, trans cooler, reverse cam and media player. Wife unit's : 2010 update FG XR6, reverse cam, HR 2300kg Hitch, German Maestro speakers, parcel shelf sub, trimmed mudflaps, batman stickers. |
28-02-2014, 09:47 AM | #32 | ||
When in doubt, GAS IT!!
Well done Mif, that's a much neater result for sure but be aware that if you don't have enough pressure on the tape and especially if the glue is still in place, under high heat situations the screen will still likely fade out. I had it happen to one I clamped on a 45C day. With with my original prototype, the tape had been removed from the board and glue cleaned off before clamping down and it's never failed even after that last heat wave of 40+ for a week.
Cheers Bushbasher
28-02-2014, 07:04 PM | #33 | |||
CNC fixer guy
One week down and still going (touches wood). It didnt cost a cent to try this so i will see if the pvc extrusion and foam tape will provide enough pressure over time. I didnt remove the ribbon at all so the factory goo would still be there. If it fails i might look at something with higher clamping force too. All the best dude.
18-11-2015, 12:25 PM | #34 | ||
Irregular member
I gave this a try over the weekend on a spare unit I have and it made a difference in elements showing solidly but half the elements were random not showing. :(
I got the clips from The Reject Shop for $2. Identical to the photos above.
2000 AU II FAIRLANE 75th ANNIVERSARY - big and shiny My hovercraft is full of eels! Movie Car Chase of the Week: Gene Hackman driving a 1971 Pontiac LeMans to chase an elevated train in The French Connection (1971). |
03-03-2020, 11:32 AM | #35 | ||
I've put a plead in AU to BF, I trying to do this fix. I just can't see how it can come out.
04-03-2020, 12:05 AM | #36 | ||
Irregular member
From memory I think you pop the plastic cover of the clock off and there is a screw, then you can pull out the whole thing and disconnect the cable.
04-03-2020, 08:01 PM | #37 | ||
Thanks, got it apart, yeap, all the little tabs broke and clock buttons fell out. Bough nalclips and the tool, and will have a go tomorrow. My tape doesn't appear to have lifted at all.
tar bye |
06-03-2020, 07:35 AM | #38 | ||
When I first read about this fix, I bought medium nalclips. Then I read it again, and saw I needed a tool for the clips. They come in small medium and large. I then bought large clips and the tool for them. I used chamie, they clips just don't open up enough. I had chopped the tool down. There's not enough tape to put the clips all the way on. so they just sit on the edge?. Too hard, I got the iron out, and all good (well lasted 10hrs so far).
When the tape fails again, I'll revisit the clips. tar bye |
06-03-2020, 08:27 AM | #39 | ||
Virtuous Bogan (TM)
Mate I went in circles with this for ages then bit the bullet and paid for it to be repaired as I was going insane.
IIRC the repair bill was around $100. Have a search for my old T2 build thread and Im pretty sure its in there, or the Fairmont I had.
