Old 09-06-2013, 11:27 PM   #1
Kevaclone
Kevaclone's Avatar
Default 99 Laser leaks in the rain
Where would water leak into the cabin, drivers side, when it rains
looked around the firewall and under the front cowl and no holes
could it be leaking around the windscreen?
03 BA XLS 6cyl Ute-Mercury Silver
04 Subaru Liberty GT Premium
99 Toyota 105 series Cruiser TD
99 5.8M Profish plate alloy carport decoration
Kevaclone is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2013, 12:56 PM   #2
russellw
russellw's Avatar
Default Re: 99 Laser leaks in the rain
Top header rail of the windscreen is one possibility but a more likely choice is the plenum chamber with either the drain holes blocked or rust from pooled water.
Russ
Old 10-06-2013, 02:44 PM   #3
Kevaclone
Kevaclone's Avatar
Hmmmm well it's for sale so I'll just park it under cover and let someone else worry about it. spent way too much on it already
Old 24-06-2013, 05:42 PM   #4
V8 EF Fairmont
Hey, I also have the same issue, wet carpet in the drivers side. Where should I be looking for water coming in?
V8 EF Fairmont is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2022, 02:50 AM   #5
LUV DE COUPE
LUV DE COUPE's Avatar
Any new ideas on this my daughter has same issue
LUV DE COUPE is offline   Reply With Quote Multi-Quote with this Post
