Old 17-09-2006, 07:01 PM   #1
Deanodriver
Default AX Telstar head replacement, worth doing timing belt as well?
I've got an AX Telstar, which has 180,000km on it.
It's been using a little coolant lately (topped up every so often), and recently overheated, and the diagnosis is a cracked head. Now, considering it's only 20,000km off it's 200K service, is it worth getting the timing belt done at the same time as the head?
My first E-series: (*gone* :() 1994 EF Futura
Current Ride: 1993 Ford Telstar GLX, maroon manual sedan, Alpine CD player
Deanodriver is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2006, 07:08 PM   #2
BlackLS
Posts: n/a
Yeah it would be, your going to have to take the head off anyway, so the belt will have to be taken off. The belt/s should cost only $30 or so (could be a seperate one for a balencer)
Old 17-09-2006, 07:19 PM   #3
Deanodriver
It'll be one belt, it's a 4cylinder (which IMO had enough power)
Old 18-09-2006, 12:10 AM   #4
dirty hands
Over Thinker
dirty hands's Avatar
the water pump runs off that belt and might be leaking
so check it out while the timing belt is off
every 50,000 km for timing belt repalcement in a telstar
My car goes Brumm Brumm
dirty hands is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2007, 01:17 PM   #5
jak_a
my 92 telstar has also done 180000 k's , and just recently replaced head gasket , my mechanic told me the timing belt was still ok but said make sure to change it before it hits 200000 , does this all sound right to you guys or should i replace it now?
jak_a is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2007, 07:34 PM   #6
smally289
growing up is optional
smally289's Avatar
Should have replaced it when the head was off IMO. Now you are up for all that labour again.
Your mechanic is not looking after you to well!
Replace the belt now unless you know exactly when it was replaced last.
Bent valves = lotsa $$
smally289 is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2007, 07:46 PM   #7
jak_a
i think your right , he quated me between $250-300 to get it done when it probaly would have only cost a fraction of that if he had done it when the head gasket was done
Old 20-05-2007, 09:14 PM   #8
dirty hands
Over Thinker
ys mechanic wanted more dollars alright
find another mechanic
proper way was to have replaced the timing belt and head in one job and water pump if needed
Old 21-05-2007, 03:10 PM   #9
jak_a
thing is my mechanic is telling me he checked out the timing belt while he was replacing the head and it was alright , can a mechanic tell if its ok by inspecting it?
Old 21-05-2007, 04:10 PM   #10
MITCHAY
You should replace timing belt at least what the intervals suggest but better before then. It's one of those things that absolutely has to be replaced before it breaks as mentioned for example bent valves.
Sounds like he wants to do the work for you but is trying to make it sound not so important for now so he can charge you labour again later.
Also as suggested check the water pump too. Lucky they didn't charge labour for me again because it started leaking after they changed the coolant (and belts). The gunk that blocked the leak was cleared and they didn't check it out properly. Still had to have my car in the shop for more time though :(
MITCHAY is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2007, 08:19 PM   #11
smally289
smally289's Avatar
For the price of a new timing belt, why not change it when it's apart?
Almost like checking the rings when you hone a cylinder to see if you can reuse them. Backwards thinking.
Old 21-05-2007, 08:36 PM   #12
jak_a
thanks to you guys i'v booked in timing belt job for later this week with lube mobile , better to be safe than sorry , only $281 complete job , in the mean time i'm looking around for a cheap water pump so they can fit that in at the same time, once again thanks for the advice
Old 22-05-2007, 11:01 AM   #13
jak_a
hi , just wondering is it absolutely necessary to replace water pump when changing timing belt? this cars costing me a fortune.
Old 22-05-2007, 12:41 PM   #14
MITCHAY
Welcome to older Japanese cars! :
If it isn't leaking then there would be no need to. I only found out I had a leak because I got a coolant flush done which removed gunk that was sealing the leak.
Just saying make sure that it is checked for leaking around it and if it needs to be done, get it done at the same time to save on labour.
Old 22-05-2007, 01:37 PM   #15
jak_a
with my luck the dude will probaly charge me a hundred bucks just to have a look :togo:
Old 22-05-2007, 11:20 PM   #16
dirty hands
Over Thinker
dont take it back to him and send me the $100 dude :
