Old 02-11-2016, 06:32 PM   #1
ten[A]cio[U]s
ten[A]cio[U]s's Avatar
Default AU drivers electric seat removal
Hey all,
In the progress of seat swapping between models, and for the life of me cannot recall how I got the rear electric seat bolts done up/undone..
I cant even find a "that works" method..
Any suggestions are very welcome, bonus points for pictures.
Cheers.
Daily: AU Forte Wagon
Project: AU Fairmont - Wants to be turbo
The Family Car: 2009 G6E Turbo
Future fun: 1968 Ford Galaxie 500
ten[A]cio[U]s is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2016, 06:37 PM   #2
ten[A]cio[U]s
Default Re: AU drivers electric seat removal
So far a torx bit in a 7mm spanner is as close as I have gotten.
Old 02-11-2016, 06:46 PM   #3
ten[A]cio[U]s
Ok update.. seems the seat is stopping earlier than it should. Tested the Fairlane and get almost another foot or room..
Any way to release the motor?
Old 02-11-2016, 09:00 PM   #4
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Is it the motor or is something blocking it?
UK
Old 02-11-2016, 09:24 PM   #5
ten[A]cio[U]s
It goes from half way back the whole way fine, up and down fine, but it feels like its hitting a stop. There is another few inches of thread left but its making a solid thunk when it stops.
I can't see anything blocking it or jammed. If it is the motor is there a way to bypass/disconnect the motor and run it forward manually.
Old 02-11-2016, 10:51 PM   #6
Uncle_Ken
Uncle_Ken's Avatar
Ill have a look at mine but I've never checked
UK
Old 05-11-2016, 09:45 PM   #7
ten[A]cio[U]s
All sorted. Trimmed an key down and gave me enough room to losen the bolts.
Issue was a slightly bent rail track causing it to jam.
Cheers for you input Uncle_Ken
Old 05-11-2016, 10:15 PM   #8
Uncle_Ken
Uncle_Ken's Avatar
Great news enjoy the seat
UK
